Another hp guess
Barney
tconnection
Another hp guess Empty Another hp guess
Post  tconnection March 10th 2012, 11:05 pm
Im waiting for the shop to get done with my block which will be ready to assembly when i get it home.
Im kinda wondering about what hp range it will about be in.
580ci
2.35 int valve
a460 head, figuring 440 int flow
The int has the ports smoothed and gasket matched
839/780 lift, 283/302@.050, 316/340@ .020, 114 lsa
1250 or 1300 cfm carb
im wanting .002 to .002.5 on the rods and .003 on the mains.
tconnection
Another hp guess Empty Re: Another hp guess
Post  cletus66 March 10th 2012, 11:12 pm
880 HP Twisted Evil
Post  Barney March 10th 2012, 11:22 pm
what compression
Barney
Barney
Post  tconnection March 10th 2012, 11:26 pm
14:1 cr and gonna put it on a 112 cl.
Im hoping for at least a 1000. or do i need more air flow?
tconnection
Post  c.evans March 10th 2012, 11:36 pm
You should make between 960 to about 975. You need a few more cubic inches, and a little more airflow for 1000 Hp. Probably get some custom pistons with a lightweight ring package and finesse things.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Barney March 10th 2012, 11:43 pm
sound about right.
Barney
Barney
Post  dfree383 March 10th 2012, 11:53 pm
X2
Post  cool40 March 11th 2012, 12:06 am
do you figure440 on the heads or do you know? i figured mine were more than they were too but 360 was the real numbers.
Post  tconnection March 11th 2012, 12:16 am
That's alot of horse power to me.
2850lb, c6, 6100 stall, 3.73, 28 0r 29'' tire.
About what 1/8 mile et will 975hp take this car if it hook up?
tconnection
Another hp guess Empty 1/8 mile et
Post  bigdaddy198 March 11th 2012, 12:24 am
probly looking at a 5.75 to a 5.95 in the 1/8th Suspect Suspect Suspect
bigdaddy198
Post  tconnection March 11th 2012, 12:29 am
Grrrrrrrrrrrrr! I hope trick flow aint doing it like that. The 2.30 int is what they say flow 412cfm out the box. I think the 2.35's is a little better. Anyway what ive done is polished all ports smoothing sharpness out of the short turns and sharp edges out of the bowls/pockets.
tconnection
Post  tconnection March 11th 2012, 12:31 am
That's real fast to me. Ive never even been in the 6's before
tconnection
Post  tconnection March 11th 2012, 12:33 am
Im good. Thanks for all the info.
Thanks alot
tconnection
Post  cool40 March 11th 2012, 12:49 am
tconnection wrote:Grrrrrrrrrrrrr! I hope trick flow aint doing it like that. The 2.30 int is what they say flow 412cfm out the box. I think the 2.35's is a little better. Anyway what ive done is polished all ports smoothing sharpness out of the short turns and sharp edges out of the bowls/pockets.
ok,so you have TFS heads? they should be what they say.mine were ald A460's that did'nt come with flow #'s.
Another hp guess Empty i would like to hear what it does run
Post  bigdaddy198 March 11th 2012, 2:11 am
please post your numbers after you get it done i would like to know the results of your improvements and good luck i know years ago when i went and made my first 10 second pass i got sick bad then when i dropped a second it happened again a good friend of mine let me make 3 passes in his 8 second camaro once again it got me it only happens when you go faster its the first time you actually feel good about tossin your cookies like i said keep us posted i for one want to know if it feels cool thanks bom bom bom
bigdaddy198
