Iron Heads
+8
DanH
lghting94
138
strokedmyford
crittersf1
tenforty_2
12 posters
Iron Heads Empty Iron Heads
Post  tenforty_2 September 25th 2011, 1:30 pm
Need a set of EX 514 or Blue Thunder iron heads.
Kirk
tenforty_2
Iron Heads Empty Re: Iron Heads
Post  crittersf1 September 25th 2011, 9:38 pm
Good luck
crittersf1
crittersf1
Post  tenforty_2 September 26th 2011, 10:10 am
crittersf1 wrote:Good luck
No kidding! Crying or Very sad
tenforty_2
Post  strokedmyford September 26th 2011, 4:41 pm
http://midstatesmuddragers.freeforums.org/iron-heads-t386.html
His name is Steve Harris, 712-259-3552
strokedmyford
strokedmyford
Iron Heads Empty Thanks
Post  tenforty_2 September 30th 2011, 10:09 am
strokedmyford wrote:http://midstatesmuddragers.freeforums.org/iron-heads-t386.html
Thanks for the information! I called him (nice guy), offered him $6000 and he declined. Sad
tenforty_2
Post  138 September 30th 2011, 10:50 am
6000+ for an intake and iron heads?... what a joke. talk about making it tuff on a ford guy. that's ridiculous.
138
Post  lghting94 September 30th 2011, 12:39 pm
Couple years ago I called and priced bare ex-514 heads and with no valves or valve job they were $3500 a pair, with ports cleaned up and a basic 45* valve job they were $4500 a pair(still no valves). so by the time you have a complete port and polish job done, competition valve job, new valves and at that size titanium would be a good idea, a new intake, and rocker girdles I dont think $6000 would touch a setup. This is the reason we are seeing fewer and fewer fords in the iron headed classes around here
lghting94
lghting94
Post  bbf-falcon September 30th 2011, 10:51 pm
IMO,the iron head rule is a JOKE anyway Rolling Eyes The truck pulling rule makers have taken the little guy out of the competition in those classes. jmo
Post  dfree383 September 30th 2011, 10:54 pm
bbf-falcon wrote:IMO,the iron head rule is a JOKE anyway Rolling Eyes The truck pulling rule makers have taken the little guy out of the competition in those classes. jmo
So uses some Iron CJ heads and Give them a run for there money...... $6000 in a set will get you some good power and alot of "Modifications"
Post  DanH October 1st 2011, 1:35 pm
little bbc guy has no problem , they can buy new for less money than aluminum
why do you think the rule states iron
DanH
Post  bbf-falcon October 1st 2011, 7:35 pm
True Rolling Eyes
Post  lghting94 October 2nd 2011, 12:31 pm
When it was a factory iron head rule fords would dominate alot of the time so the rulemaker chevy guys had to give themselves a chance and allow aftermarket iron. Iron CJ's can be very competitive but have their limits.
lghting94
lghting94
Post  69F100 October 5th 2011, 5:43 pm
342g might be saling his BT heads https://www.429-460.com/t11714-heads-blue-thunder
Post  56Tbird October 5th 2011, 7:09 pm
69F100 wrote:342g might be saling his BT heads https://www.429-460.com/t11714-heads-blue-thunder
His are aluminum
56Tbird
56Tbird
Post  res0rli9 October 5th 2011, 11:16 pm
His are aluminum
And NOT for sale anymore
Post  res0rli9 October 5th 2011, 11:54 pm
Here's your heads..Better be Quick
http://www.460ford.com/forum/showthread.php?t=156142
Post  dfree383 October 6th 2011, 3:02 am
F'n highway robbery is what that is.
Post  69F100 October 6th 2011, 6:20 am
ok his is not for sale anymore just seen that
Post  bbf-falcon October 7th 2011, 9:09 pm
If you buy a set of EX514's,better make sure you can find someone WILLING too wrestle them around and do the job correct,and also make sure that if they are the ones from the last batch,that they have the water passage issue fixed. I hear that T.Bishoff has a couple of new sets,but won't sell OR port them unless he built or builds your engine. Another rumor from a reliable source told me just today that a new style (revamed)SCJ iron head is in the final stages of design and could possibly be on the market shortly.Said the proto type has flowed in the High 400 range on intake. he said he has some literature on it,but did'nt personally see it.
Post  BOSS 429 October 8th 2011, 1:38 am
138 wrote:6000+ for an intake and iron heads?... what a joke. talk about making it tuff on a ford guy. that's ridiculous.
no at one time they were 3500,but then they changed their mind and only sold them c n ced for 4500.00 which is a good price for this head, the cutters are very pricy to mach these heads,and you go thru a few of them, then hand work them a little more,and you have a very good head, i just sold a pair bare for 5250.00
the iron head rule is out dated,it was to keep the price down,and now look what happened?
Post  dfree383 October 8th 2011, 3:35 am
The problem is the rules need to be expanded to say "Factory Production Iron Heads Only"
Iron Heads Empty Heard the same thing
Post  tenforty_2 October 8th 2011, 11:23 am
bbf-falcon wrote:Another rumor from a reliable source told me just today that a new style (revamed)SCJ iron head is in the final stages of design and could possibly be on the market shortly.Said the proto type has flowed in the High 400 range on intake. he said he has some literature on it,but did'nt personally see it.
I have heard the same thing (will kill the value of any old iron head). I think our pulling group has dug a hole that will take for ever to fix. I don't know all of the history behind what has happened since I have only been pulling with them for a couple of years. Rumor has it that our 6200 lb "altered steet" began as a "budget class" to allow the less fortunate with an option to pull. They split a 6300 lb modified class and created the 6200 lb altered street class. The 6300 modified class is still restricted to an iron head and the rules for this class specifically stated that an EX514 head was not allowed until last year. This class only has four trucks that compete for points: two all chevy trucks, one ford with a chevy motor Evil or Very Mad and one dodge. No pure breed fords!
I think the original version of the 6200 lb rules only stated "iron heads". The first season a chevy won the points (not sure what heads he was running). Ironically during the second season it was a ford that benefited from the way the rules were written and he won nearly every pull and the points with BT iron heads. A ford has not won a single pull in this class since he stepped down. This gave the chevy guys an excuse to go out and buy mostly the RHS head since "the ford ran an aftermarket head that one year".
As I did my research and started building my truck my plan was to go with either the BT or EX514 head. I couldn't find any BT heads so I started talking to some of the other guys in the group about the EX514 heads. I was told that "that head will not be allowed" in the 6200 lb class. I approached the rules commitee with the idea and they said no way. They said that the EX514 was a far more superior cylinder head than any available iron head on the market for the chevy Rolling Eyes .
It's the same old story all over the country in truck pulling and some mud bogging groups. Iron head rules kill the fords and nobody wants to switch to aluminum because they "have too much money in their iron heads" and it will create an unfair advantage for the fords if they run aluminum and the chevys are stuck running iron or have to cut their losses and go with aluminum. The 6200 lb and the 6300 lb classes do not have a ford rep on the rules committee because.................well there are no fords in the 6300 class and very few in the 6200 lb class! I could sell my truck and go buy those EX514 heads for $8500, but then I wouldn't have a truck to put them in scratch Laughing
Atleast we havea place like this to vent frustration!
Kirk
tenforty_2
Post  bbf-falcon October 8th 2011, 2:59 pm
dfree383 wrote:[quote the iron head rule is out dated,it was to keep the price down,and now look what happened?
[/quote]
X2 Dave I agree 100%. Especially in the Mod. STREET classes. It would at least let the little guy have a fair chance. I know that the rules are different in different areas,but imo the street classes should NOT be allowed to have weight hanging off the front of the truck.Leave that for the S/S and open classes.JMO Smile
