Axle bearing seal ?
Axle bearing seal ?
This is the bearings with the oring on the outside, does it matter which way the bearing gets pressed on ? the reason i ask is the oring is towards one side more than the other,and i looked at diffrent axle pictures on the net and its shows both,some show the seal closer to the flange and some show it closer to the spline end ? maybe it doesent matter just wanted a second opinion.
nuclearcobra- BBF CONTRIBUTOR
Re: Axle bearing seal ?
This is oddly timed. I recently purchased a set of used Moser axles. The bearing was pressed on with the O ring closer to flange. I was going to post a question to see if it mattered.
Looking at my axle inside the housing, it looks like it shouldn't make a difference as long as the O ring comes into contact with the housing flange but I really don't know for sure.
cheqmate5000- Posts : 2
I just talked to moser the bearings are pressed on right,the seal side is towards the flange which makes me happy as well because we just had my buddys pressed on that way saturday.
I always put a seal in the housing also as sometimes the oring will weep oil and all you need is a drip off oil hanging there to get punted at tech
Frank Merkl- Posts : 1524
A little clear silicon on the inside of the flange wont hurt, dont use the TA31 its harder to clean up lol.
I have seen it done both ways if the bearing has just a simple O-ring seal on it's OD. And if the axle bearing has dust/race lip seals on both sides of the bearing it shouldn't matter anyway. But if the axle bearing is the type that only has one dust/race seal on one side of the bearing & is "open" (no seal) on the other side, the "open" side faces inward & the dust/race seal faces outward.
There are some axle bearings out there that do use a wider tapered lip OD seal instead of a narrow O-ring OD seal on the bearing, direction is important on them (last one I saw like that was on a Moser axle).
DILLIGASDAVE- Posts : 2262
Yep these were moser axles ans they have the dust seal on both sides,anyway no more leakin
» 9" Axle , Bearing Fit
» What axle bearing do I need?
» need 31 spline axle help
» KING MAIN BEARING CLEARANCE'S AT PARTING LINE..?
