Nitrous problems ,car will not pick up
1970 ford maverick
10SHOTS
Nitrous problems ,car will not pick up Empty Nitrous problems ,car will not pick up
Post  10SHOTS October 3rd 2011, 11:12 am
I have been running an edelbrock plate system with a 89 nitrous jet and a 85 fuel jet with 5 1/4 pounds of fuel pessure pulling 9 degrees of timing for a total of 26 on the spray.car ran a 5.64 ,moved the jets up to a 102 on the nitrous and a 99 on the fuel side and the car ran a 5.66 and a 5.68 pulling 11 degrees total 24
the mph was not working at this track last night , but i took the car a couple months back to a different track i believe it picked up 1 miles an hour .,fuel pump is a magnafuel 500 set @26 pounds
converter has been checked its a 5000 ptc 9 inch car weighs 3240 ,c6 trans,any help with this would be appreciated,thanks UPDATE , new big shot plate 80 fuel and 90 nos jet. 5.1/4 pounds fuel pressure pullin 12 degrees of timing went 5.61 looking at the strap it looks like i can ad a degree of timing back in , buying a crank trigger so i can phase in the distributor .
4.390 bore
6.800 rod
4.300 stroke
tfs intake ,1150 dominator
69cc tfs street heads ported
35 degree timing
probe flat top pistons 13.6 compression
cam specs
275-283 @.050 .735 .733 lift
110 lobe sep installed @ 106 centerline
trans brake c6 with a 5000 converter 29x10.5 tire 4.10 gears
car with driver 3240
ngk number 10 plugs
10SHOTS
10SHOTS
Nitrous problems ,car will not pick up Empty Re: Nitrous problems ,car will not pick up
Post  1970 ford maverick October 3rd 2011, 6:22 pm
[/quote]maybe try putting some timming back into it,say 4degrees and 1/2 pound of fuel,,Now if, your planning on hitting it harder with the spray?, I would tighten the converter up alittle. keep a close eye on your plugs , hope your run ngk's ?, I like to run a #8 to#9 anything obove 150 shot, hope this will help ya. 1970 mavrick
1970 ford maverick
1970 ford maverick
Post  richter69 October 3rd 2011, 6:51 pm
60' numbers? 330 numbers?
Post  bruno October 3rd 2011, 8:32 pm
first of all is i would start out with a smaller tune ....... second the tunes you are talking about are way to rich . give S-I a call and discuss some baseline tunes before you do some serious damage ... btw what does she run n/a ?
oh and let me add one thing i run a 10 jet spread on my plate and the same fuel flow #s 5.25 and she might still be a hair rich ..........
http://WWW.CKRME.COM
Post  10SHOTS October 4th 2011, 9:11 am
richter69 wrote:60' numbers? 330 numbers?
1.26 60 Foot, no 330
10SHOTS
10SHOTS
Post  10SHOTS October 4th 2011, 9:14 am
bruno wrote:first of all is i would start out with a smaller tune ....... second the tunes you are talking about are way to rich . give S-I a call and discuss some baseline tunes before you do some serious damage ... btw what does she run n/a ?
how much timing are you pulling out thanks
10SHOTS
10SHOTS
Post  richter69 October 4th 2011, 10:50 am
1.26 on all runs?
Post  10SHOTS October 4th 2011, 11:23 am
1.26 on all runs?
1.26 and 1.27 same on both jet changes.
my plate does not have a lot of spray bar holes. i been thinking about upgrading the plate to see if it will help some.
10SHOTS
10SHOTS
Post  10SHOTS October 4th 2011, 11:26 am
i have been 5.99, that day only could get a 6.10
10SHOTS
10SHOTS
Post  bruno October 4th 2011, 4:00 pm
when im on my 82 jet tune i gain between 7-9mph ..... just a thought
Post  10SHOTS October 4th 2011, 4:04 pm
bruno wrote:when im on my 82 jet tune i gain between 7-9mph ..... just a thought
on this kit 104 104 jets is 250 shot. nos 225 is 82 i dont know why that is, unless its the the spray bar holes
10SHOTS
10SHOTS
Post  richter69 October 4th 2011, 5:30 pm
We did a 102n 85f, 5.5psi with a 64 hole Cold Fusion plate on the kids 383 truck, went from a 13.20 motor pass to a 11.15 on the hose, pulled 10* from a 36* total timing.
My NX plate is a 8 hole deal that uses square jetting at the 200 and up levels, but its an alky set up.
Honestly I'd box up the plate, pills, noids etc and send it all to Steve J. at I.S.
Post  bruno October 4th 2011, 8:17 pm
richter69 wrote:We did a 102n 85f, 5.5psi with a 64 hole Cold Fusion plate on the kids 383 truck, went from a 13.20 motor pass to a 11.15 on the hose, pulled 10* from a 36* total timing.
x100000000000000000000
Post  chuck October 5th 2011, 11:01 pm
Call ult. Conv. Get a true 10" conv. 4000 rpm, go with a 3.73 gear. The harder you spray the car the more it will like. Your motor passes will suffer, but she will like the spray.
chuck
Post  whatbumper October 6th 2011, 11:52 am
sounds to me like the cam is not ideal.
Post  10SHOTS October 6th 2011, 2:45 pm
whatbumper wrote:sounds to me like the cam is not ideal.
The cam is not a nitrous cam but my cam grinder says the car will slow down with only a 250 shot with a nitrous cam. if i could get a cam that would pick me up a tenth on motor with my set up i would buy it .i just dont feel its possible
10SHOTS
10SHOTS
Post  whatbumper October 6th 2011, 4:19 pm
I just know no matter how much nitrous I threw on my last nitrous motor it would only pick up about 180hp so that is what we jetted it at. Yours just sounded familiar.
Post  10SHOTS October 6th 2011, 4:34 pm
whatbumper wrote:I just know no matter how much nitrous I threw on my last nitrous motor it would only pick up about 180hp so that is what we jetted it at. Yours just sounded familiar.
You saying you was using a motor cam and that was happening ?
10SHOTS
10SHOTS
Post  whatbumper October 6th 2011, 6:06 pm
Yes. I had a NA cam
Post  bruno October 21st 2011, 1:26 pm
have you talekd with Lem yet ?
Post  10SHOTS October 24th 2011, 11:27 am
not yet , think i should ?
10SHOTS
10SHOTS
Nitrous problems ,car will not pick up Empty big shot plate
Post  10SHOTS October 24th 2011, 11:32 am
so i bought a big shot plate and put 90 nitrous and 80 fuel jets, should be around a 250 shot, 5 1/4 pound fuel pressure ,pulled 12 degrees of timing and went 5.61 , plugs look like i can ad a degree of timing back in so with a little more tuning i thing i can get into the 50s , back to the track again, 85 fuel and 95 nos jets pulling 13 degrees of timing, went 5.56 . the motor dont come down any on the shifts,need a different converter. i think im going to stop at this point with jets
10SHOTS
10SHOTS
Post  bruno October 24th 2011, 12:20 pm
10SHOTS wrote:so i bought a big shot plate and put 90 nitrous and 80 fuel jets, should be around a 250 shot, 5 1/4 pound fuel pressure ,pulled 12 degrees of timing and went 5.61 , plugs look like i can ad a degree of timing back in so with a little more tuning i thing i can get into the 50s
cool , now you are on the right track
Post  1970 ford maverick November 11th 2011, 6:22 pm
10SHOTS wrote:so i bought a big shot plate and put 90 nitrous and 80 fuel jets, should be around a 250 shot, 5 1/4 pound fuel pressure ,pulled 12 degrees of timing and went 5.61 , plugs look like i can ad a degree of timing back in so with a little more tuning i thing i can get into the 50s , back to the track again, 95 fuel and 85 nos jets pulling 13 degrees of timing, went 5.56 . the motor dont come down any on the shifts, i think im going to stop at this point with jets
"10SHOTS",Question?,you said that when you went back to the track you changed jets from 90n 80f and ran 5.61. Then changed to 95f and 85n jets ???,and went a 5.56?,Congrats on a real nice pass! THANKS,MAVMAN.
Last edited by 1970 ford maverick on November 14th 2011, 5:19 pm; edited 1 time in total
1970 ford maverick
1970 ford maverick
Post  Curt November 11th 2011, 6:27 pm
When I can't pick my car up, I talekd to Lem. He tells me I need to exercise and learn to spell.
