Nitrous problems ,car will not pick up
1970 ford maverick
10SHOTS
Page 2 of 2 Previous  1, 2
Nitrous problems ,car will not pick up - Page 2 Empty Re: Nitrous problems ,car will not pick up
Post  1970 ford maverick November 15th 2011, 2:58 pm
10SHOTS wrote:so i bought a big shot plate and put 90 nitrous and 80 fuel jets, should be around a 250 shot, 5 1/4 pound fuel pressure ,pulled 12 degrees of timing and went 5.61 , plugs look like i can ad a degree of timing back in so with a little more tuning i thing i can get into the 50s , back to the track again, 95 fuel and 85 nos jets pulling 13 degrees of timing, went 5.56 . the motor dont come down any on the shifts, i think im going to stop at this point with jets
"10SHOTS",Question for you,you went faster with more Fuel than Nos?,Thanks,MAVMAN 95FUEL and 85NOS ?
1970 ford maverick
1970 ford maverick
Post  10SHOTS November 15th 2011, 4:49 pm
Sorry , meant 95 Nos and 85 fuel , thats a 275 shot on the big shot jet map
10SHOTS
10SHOTS
Post  1970 ford maverick November 15th 2011, 6:10 pm
Thanks"10SHOTS" I have a similar build and run about the same #s with a bigshot plate. Thanks for sharing the info,MAVMAN
1970 ford maverick
1970 ford maverick
Post  10SHOTS November 16th 2011, 10:46 am
The new jet map for the big shot plate is much better, look into it. you 95 nos 85 fuel pull the engine timing down to 22 degrees , i run sonoco 116 maximal fuel. #10 ngk plugs . If i could buy a new converter i think a could run in the low 40s
10SHOTS
10SHOTS
