540 Long block / Boss9 block / AR CJ cylinder heads - $3300 OBO
540 cubic inch. AR CJ aluminum heads, comp springs, ferrara stainless valves , 2.250 -1.760 , crane gold rockers , ridgeway stud girdle, NO POLY LOCKS !! , Heads ported by abbott racing in Texas. Short block is a Boss9 service block that was lightened, 4.530 bore ,D9 truck crank welded and offset ground, Aluminum rods, large dome pistons, roller camshaft, roller lifters, comp pushrods , rear sump pan with windage tray, pump and pickup, fluidampner balancer, NO TIMING COVER !! . Motorsport valve covers included.
This was in the Boss302 drag car that is for sale also. Engine ran 8.70's with a powerglide and 4.30 gears with alcohol injection. Car was not safe for that speed and was told to park it. Engine has not ran in 8 years, is appart for inspection and just bolted back together for the pictures. Block has one sleeve in it. Grouted to the bottom of the water pump holes.
$3300 OBO and you pickup.in Western Maryland
301-478-3097
Travis
301-478-3097
Travis
Last edited by TravisRice on September 28th 2009, 7:52 pm; edited 3 times in total (Reason for editing : reduced price)
TravisRice- BBF CONTRIBUTOR
Re: 540 Long block / Boss9 block / AR CJ cylinder heads - $3300 OBO
reduced price from $3600 to $3300.
Travis
Travis
» A460 long block wit d460 heads
» Kaase P51 Heads NIB - Atlanta
» DOVE-A 429 Long Block For Sale with Edelbrock heads (SOLD)
» 429 cobra jet long block
» looking for boss9 or A441 heads.
