My street car build.
darren
Hi guy's here is some pictures of my 557ci build and a link to my build on photobucket
enjoy, Darren
https://s890.photobucket.com/home/557f1/index
enjoy, Darren
darren- Posts : 64
Re: My street car build.
shaft rockers.got any green oil?
Gonna have alot of Squeeze.....
Cool40, I run redline oil in my supercharged honda dragbike engine ,loved the stuff so I will use that or joe gibbs,
dfree383, it worked out to be 12.5 comp and I have snowperformance muscle car methanol/water injection to carm it down.
darren- Posts : 64
welcome broken rocker stand pedestals
the Coug- Posts : 3055
How big is the cam?
Need to look at your calculations, FT with those heads and typical 0 deck get you in the 13.5:1 + range.
Cam is isky .730 valve lift,274 @ .050 108 lobe center
pistons are .020' down the bore,
chambers were finished at 75cc.
I will have to dig out my book with all the measurements
darren- Posts : 64
Cam specs are going to cost you some power. Might consider something custom.
build
I'm not familiar with the screen in the bottom, is it to control oil splash?
D-Rail- Posts : 12
Hi D-rail.It is
that is a downwards crank scraper .
http://www.crank-scrapers.com/What%20is%20a%20crank-scraper.html
darren- Posts : 64
My new oil pump arrived yesterday.
Thanks! B f evans Ford Raceparts.
Wow! there is a hugh differance between the Mellings and the Kaase oil pump
dfree383 ,how much would I gain from a custom grind camshaft.
darren- Posts : 64
[quote="darren"]My new oil pump arrived yesterday.
yes but once you break an oil pump and totally trash the whole engine it seems like not so much then, pay now or pay later
This is going to be a pretty nasty "street" engine.
IcallhimGeorge- BBF CONTRIBUTOR
The Coug ,you are absolutely right,
IcallhimGeorge ,Yes it is, I gotta beat on my frineds with their Chevys.LOL!
darren- Posts : 64
darren I see you have invested lots of cash in this engine, why skimp now and Kaase makes great pump, it is way beefier than any Melling I have a cracked one, I am glad I bought a Kaase...
Thanks for that ,I appreciate the imput and honesty
darren- Posts : 64
darren wrote:My new oil pump arrived yesterday.
Depends, could be a bunch depending on the combo. Issues you have are a single pattern, ford don't respond well to those, due to the weak exhaust port.
Mock up that Kaase pump and check it for crank clearance. We've all had to grind on the pump a bit to get it to clear the crank...
jbozzelle- Posts : 3705
Cool Thanks for that.
I did see on another post a picture of one that had been clearanced,
darren- Posts : 64
Yeah it's been a couple of months so I better update it.
my engine is fineshed except for the drive mandrel for the vacunm pump.
I have finished all the major work on the chassis ,front suspension,steering,x-member and the irs is done,
darren- Posts : 64
» 557 TFS street build 861 hp-753 tq
» 521 STREET/ STRIP BUILD
» P-51 Street Build
» P-51 Street Build
