Rear main seal replace
sasilverbullet
My rear main seal is leaking a bunch on my 70 Lincoln MK III w/stock 460 and trans. I'll be pulling the tranny soon to replace the flexplate so I was thinking I'd whip out the rear main seal while I was at it.
Some questions...
1. Am I making things worse or better by wanting to do the rear main seal at the same time as the flexplate?
2. Fel pro makes two kits, both are two piece, one is rubber the other is "vitron" - which is better?
3. Do I have to drop the oil pan?
4. If I have to drop the oil pan, is there anything I should do with the oil pickup assembly? (seems to be oiling fine)
5. If needed, will dropping the oil pan be harder with the tranny removed?
6. I know I'll need two new exhaust donuts and a oil pan gasket, anything else you can think of?
Some questions...
sasilverbullet- Posts : 9
Re: Rear main seal replace
Well all I can think is that it is going to be near impossible to drop the pan and have enough room to change it. It is the right time to change it but the pan will need to come down a lot more then the little bit of room you will have from the pan to the cross member. I would think while you have the tranny out you will have to lift the motor some for extra clearance.
jasonf- BBF CONTRIBUTOR
Not only are you going to need to drop the oil pan but you'll have to drop the rear main cap to change the seal too. You'll also need room to ge tthe wrench and a socket in there to get the main bolts loose. You may be able to get enough room with it in the car or you may have to get creative...
jbozzelle- Posts : 3705
Jason you can do it with a cutting torch just whack out the cross member and the pan should come out. you might have to cut the tie rods to but no biggy....... He might have a few problems getting it all back together but ..................... Presonally I think he might aught to remove the engine, be easier.....
the Coug- Posts : 3055
I agree with Randy I would just leave the trans in the car and pull the engine that way you don't loss all your trans fuild.It make changing the flex plate and rear main alot easier than laying on your back if you don't have a lift to work under.
Jim
Jim
the Coug wrote:Jason you can do it with a cutting torch just whack out the cross member and the pan should come out. you might have to cut the tie rods to but no biggy....... He might have a few problems getting it all back together but ..................... Presonally I think he might aught to remove the engine, be easier.....
» Rear main seal ?
» Rear Main Seal
» Rear Main Seal
» rear main seal problem
» One piece rear main seal
» Rear Main Seal
» Rear Main Seal
