pistons
the1969fordguyinky
dr's wife racing
pistons
I bought these a while back.They were bought for weisco pistons for stock valve location heads to make a 521 30 over with a 6.8 rod and a 4.3 crank.They do not appear to be stock valve location I tried to look them up but could not come up with anything called weisco but was left on hold longer than I could stay on the phone at work Part # is 5038H3 they are flat tops.I would be thankful for any help Ward.
Re: pistons
http://www.wiseco.be/Documents/protru/CompleteCatalog.pdf
BOSS 429- Posts : 2372
Re: pistons
For what ever reason I can't get either my work or home computer to open the file ????? I've tried numerious times.
Re: pistons
I opened it up and did a search for that PN. No such part in that catalog.
the1969fordguyinky- Posts : 237
Re: pistons
Thanks I double checked the part # and it is correct.Any bodyelse hae any suggestions?
Pictures added
The straight line is the center line over the wrist pin. The circle is a mark left by valve of what was supposed to be a standard CJ head. I think he may have had new type SCJ instead?
Re: pistons
Ward,
I could be mistaken, but that almost looks like it could be a relief for the A460 heads..
QtrWarrior- Posts : 2703
Re: pistons
dr's wife racing wrote:I bought these a while back.They were bought for weisco pistons for stock valve location heads to make a 521 30 over with a 6.8 rod and a 4.3 crank.They do not appear to be stock valve location I tried to look them up but could not come up with anything called weisco but was left on hold longer than I could stay on the phone at work Part # is 5038H3 they are flat tops.I would be thankful for any help Ward.
I'd call weisco direct and give them the number as it could be a custom piston. If its for the A heads I got a deal for you.
Ace
powerstrokeace- Posts : 1496
Re: pistons
dr's wife racing wrote:The straight line is the center line over the wrist pin. The circle is a mark left by valve of what was supposed to be a standard CJ head. I think he may have had new type SCJ instead?
If it looks like anything from a BB Ford, then I agree with Mikey and think it may be an A-460 piston. Maybe the guy selling them didn't know what he was talking about and was miscommunicating with the buyer. If whoever put the standard type OEM head on that piston, had used clay and mocked up, they would have easily seen that the valve relief was way off.
Charlie
c.evans- BBF VENDOR SPONSOR
Re: pistons
I found an old post where Bruno sold a set with that exact part # and they were for his E-bok heads with std valve placement
http://www.460ford.com/forum/archive/index.php/t-126364.html
Nick's pistons have extra flycut work, but it's the same. If you look close you can see the 5038H3
Ward, it looks like the valve ding mark in your pistons are in the exact same spot where Nick had the flycut deepened on his pistons. I think your prior owner just had to much lift or bad cam timing and had some p/v contact.
Edit: found a little more info.
I used the info from Bruno's old ad above and did a search. The 5038H3 was for a single piston from a kit with rings:
http://www.summitracing.com/parts/WIS-PT038H3/
Looks to be not available any longer, so that's why it's not in the Wiseco catalog.
Re: pistons
Weisco finally answered my e mail They are for a 30 thou over bore 4.3 stroke crank and a 6.8 rod.for heads with a stock valve location.I think they missed?? They should be fine with a fly cut job. I'm not sure if I will will use them at this point or not,but at least I got them fairly cheap.They can always make cool ash trays.
» rotating ass. push rods msd pistons ''''c-460 pistons added to rotating assembly''''
» JE PISTONS
» pistons
» looking to buy pistons
» pistons
» JE PISTONS
» pistons
» pistons
