looking to buy pistons
racinghabbit
what kind of pistons do you guys use on your race engines???? 12.5 :1 compression.?????? flat top..forged..
racinghabbit- Posts : 575
Re: looking to buy pistons
12.5:1 is such a wasted compression as you need race gas anyways, so go to 14:1 or 15:1 and get more power
John Myrick- BBF CONTRIBUTOR
it will depend on what size engine you are building to know what piston is needed for that cr
It just a matter of opinion.. If your freshening up a motor and you are at 9.94 compression and there is a simple piston swap to get it up to 12.5... I'll take it ., Not going to spend a ton of money to get to 14....
What bore, Stroke, rods and Heads?
A piston swap cost money however you look at it.if its gona take a custom piston the cost is about the same whatever your compression.you'd like 14.1
501 cid
6.700 rod
4.14 crank stroke
ported dove- c heads 73cc chamber (just checked at machine shop)
4.390 bore
.015 below deck
.040 head gasket..
current pistons 28cc dish srp154166... 9.94:1 compression.
This is a good running motor just want to fresh it up and get more compression.. NO NEED TO GO BROKE ...
found pistons that are 3cc dish that will slide right in..srp 150725
But i do like good advice.. If i could find a piston that will get me to 14 compression i'd like to have it...
I cant find a lot of options for this motor the way its built... But i might be mission something!
6.700 rod
4.14 crank stroke
4.390 bore
.015 below deck
.040 head gasket..
i am running an eagle CAST crank.... can it support 14:1 compression.??
Just put a probe FT in it, they a reasonably priced and work great.
dfree383 wrote:Just put a probe FT in it, they a reasonably priced and work great.
X2 To get from 12:1 to 14:1 in this case will be a change from a shelf deal to a custom one. $400 vs $800
And zero deck it.....
I called eagle, they said to stay under 12:1 on there cast crank....
probe doesn't offer a piston to fit
http://www.probeindustries.com/Ford_514_3_0cc_Flat_Top_SRS_Pistons_p/14781.htm
These will work fine. Won't need to deck it and will need a little thicker gasket.
Guys have been running cast cranks for years with higher static compression ration, not a problem IMO
racinghabbit wrote:probe doesn't offer a piston to fit
They're out of stock at the moment.....and the SRP will work fine for what you're doing.
Mark O'Neal- Posts : 286
A flat top will not get you 14.1 cr. though. You will need a dome.
i'm going to use the srp pistons. at 12.5:1 compression... not going to push it... I like my motor the way it was at 9.5:1, so i'm pretty sure its only going to be even more enjoyable.......
» Pistons
» pistons
» arias dome pistons .030
» Like to find some used standard H.o 5.0 forged pistons
» WTB Pistons\crank
» pistons
» WTB Pistons\crank
