Magna Fuel Prostar seal
Magna Fuel Prostar seal Empty Magna Fuel Prostar seal
Post  Budman November 13th 2011, 11:21 am
I am changing the leaky seals in my Prostar 500. The bottom o-ring is easy but how does one get to the upper shaft seal?
Budman
Budman
Magna Fuel Prostar seal Empty Re: Magna Fuel Prostar seal
Post  richter69 November 13th 2011, 1:01 pm
Take the rotor and vanes off, then remove the motor. Then just take a pick and pull the seal out. Push a new seal in the cavity and your good to go. Make sure the lower bearing on the armature spins freely, fuel hets up into it and it will rust and lock up. I may have a part number for the bearing if you need it.
Magna Fuel Prostar seal Empty motor off
Post  Budman November 13th 2011, 2:11 pm
Thanks,
Does the motor push out hard (the bearing from the main body)? The bearin is still in the lower
body and I am not sure how much press is on it, a few light taps?
Budman
Budman
Magna Fuel Prostar seal Empty fuel pump
Post  Budman November 13th 2011, 2:51 pm
Got it apart...thanks for the help!
Budman
Budman
Post  richter69 November 13th 2011, 3:59 pm
on mine the lower bearing was pressed on the armature shaft, they may not all be the same though.
