adjustable fuel regulator installed on stock Ford SD fuel rails
adjustable fuel regulator installed on stock Ford SD fuel rails Empty adjustable fuel regulator installed on stock Ford SD fuel rails
Post  mgawat October 19th 2014, 1:57 pm
Hey gang,
Stupid question time. I noticed on the stock 1995 7.5 EFI fuel railes, the stock fuel regulator mounts to a triangle mounted plate on the fuel rail. All the aftermarket adjustable fuel regulators I see are mounted with a nipple. Is there an adapter commercially available for adapting that factory triangle plate to a nipple styles so I an install a adjustable fuel regulator. Second, is there a commercially available pipe T so I can also mount a fuel pressure gauge next to it easily so I can properly adjust the fuel pressure?
mgawat
adjustable fuel regulator installed on stock Ford SD fuel rails Empty Re: adjustable fuel regulator installed on stock Ford SD fuel rails
Post  J.Toney October 20th 2014, 10:23 am
I'll try to find it, but used a BBK adjustable reg. I believe either Randy M. or Scott J. tipped me off onto it. I thought the app was a 5.0 mustang.
Isn't there a schrader valve already in your stock rail? I seem to remeber my '96 F-250 having this
J.Toney
J.Toney
Post  mgawat October 20th 2014, 12:24 pm
yes but the fuel regulator is a seperate mount on a triangle plate at the return line conmnection.
mgawat
Post  D. Sea October 21st 2014, 8:16 am
Three bolts under the triangle.
D. Sea
D. Sea
