Holley Fuel Regulator
Holley Fuel Regulator Empty Holley Fuel Regulator
Post  747JetMech July 30th 2014, 5:06 pm
I am ordering a new fuel tank pick up from RobbMc with -8 pickup for my Maverick. I found a Holley fuel regulator on the car with the part number 34R-6657B. I want to run a bypass line back to the tank. I cant find any information on this regulator to tell if it can be used for bypassing fuel or just dead head to carb.
I am planning on using a 100 micron filter pre pump and 40 micron after. Does this sound right to you guys?
Thanks for the help.
Tom
747JetMech
747JetMech
Holley Fuel Regulator Empty Re: Holley Fuel Regulator
Post  kim July 30th 2014, 7:47 pm
That's just a casting no, not a part no. It could be either a 12-803 which has 3/8 NPT ports and a .220 restriction, and is adjustable from 4.5 ro 9 psi, or it could be a 12-804 which is identical, but regulates from 1-4psi. I don't think you'll be able to tell by looking at them. You'll have to hook it up to a guage and see what it puts out. If it's chrome, the part no's are 12-501, adn 12-500, respectively.
kim
Holley Fuel Regulator Empty Thanks Kim
Post  747JetMech August 1st 2014, 2:10 pm
I did some more searching and found that these old regulators look almost identical. There looks to be 2 kinds. Bypass and non bypass. The way you tell is if both horizontal outlets are just that, then it is a non bypass regulator. If one the horizontal outlet and one horizontal inlet, then its a bypass type.
I don't know if the old regulators are marked inlet - outlet....
I also found I was running a 35 micron filter before the pump... Bad.. It was the Earls type with the bronze filter.
Tom
747JetMech
747JetMech
