Replacement ex. valves for edelbrock heads
Replacement ex. valves for edelbrock heads  Empty Replacement ex. valves for edelbrock heads
Post  manofmerc November 15th 2011, 3:55 pm
What do you all recomend I use to replace the ex. valves in my edelbrock heads .These are std. size 1.76 .I would like something a bit lighter that the stock edelbrock and I intend to keep the same 1.76 size thanks Doug
manofmerc
Replacement ex. valves for edelbrock heads  Empty Re: Replacement ex. valves for edelbrock heads
Post  c.evans November 15th 2011, 6:33 pm
There's not anything that is going to be "a bit lighter" to speak of,,,,,,,unless you go with titanium valves. That being said, I'd use the FRPP A-429 exhaust valves. They flow a good bit better because of their tulip shape on the backside. I believe Lem has them in stock.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Replacement ex. valves for edelbrock heads  Empty Thanks
Post  manofmerc November 16th 2011, 5:36 am
Mr.Charlie thanks from what I see they are longer than my 4.960 edel valves can they be shortened ?I have a couple bent valves in my heads My machinist wanted something lighter .Thanks again Doug
manofmerc
Post  rmcomprandy November 16th 2011, 11:42 am
manofmerc wrote:What do you all recomend I use to replace the ex. valves in my edelbrock heads .These are std. size 1.76 .I would like something a bit lighter that the stock edelbrock and I intend to keep the same 1.76 size thanks Doug
I use the #2007SG valves from S.I. for use in the Edelbrock heads. They are normally for a Pontiac and are 1.770" in diameter. Nothing special however, they fit.
Post  c.evans November 16th 2011, 12:46 pm
Doug,
No, they can't be shortened that .100". It will ruin the tip and tip length, and affect your valve spring installed height.
I forgot that Edelbrock used that shorter "big chamber" valve, so FRPP's A-429 valves (which are 5.060") won't work for you. S-I does make the shorter big chamber valves, and/or you can use the Pontiac valve that Randy mentioned. Your machinist should have S-I catalogs, REV, Ferrea, and Manley catalogs if he's a cylinder head guy. He can look up your options in any of those catalogs.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  rmcomprandy November 16th 2011, 7:14 pm
c.evans wrote:Doug,
Charlie
The shorter Ford valve has a .350" tip length and 1.750" head diameter. It can't be used easily in an Edelbrock head.
The S.I. #2007SG is 4.970" OAL and has a .250" tip length.
Replacement ex. valves for edelbrock heads  Empty Valve info
Post  manofmerc November 17th 2011, 6:44 am
Thanks for the help guys .Mr.Malick do you have those S I valves in stock ?Thanks again Doug
manofmerc
Post  rmcomprandy November 17th 2011, 11:42 am
manofmerc wrote:Thanks for the help guys .Mr.Malick do you have those S I valves in stock ?Thanks again Doug
I have one set of 8 because I ordered them for a D3 customer who never paid for them but, usually NO, not those ... I buy them as I need them. It only takes a few days.
