valves for scj heads
i bought a set of aluminum scj heads a few weeks ago bare, they are new my question is what size/length valve do i need to run with them the cam i am gonna run is right at 700 lift also it is a street car mostly
fordmonsta- Posts : 236
Re: valves for scj heads
You need the 2.200" X 5.265" long intake valve and the 1.760" X 5.060" long exhaust valve. The Ford part numbers are A-429-____ something or another. Lem has them in stock and I'm sure there are other sources also.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
Like Charlie said, the FRPP valve are as good as anything i've seen for those heads. .700" lift is doable with the std. frpp valves......it's just a matter of putting the correct spring/retainer/keeper package together.
» the dove c heads i bought , i measured the intake valves they were 2.250 assuming these are not stock valves ?
» TFS 290 and 325 heads exhaust valves
» dove c heads with cj valves
» Which piston with dove heads and 2.25 valves?
» Replacement ex. valves for edelbrock heads
