Help with new build?
Help with new build? Empty Help with new build?
Post  Copperhead November 15th 2011, 4:24 pm
Well,.......
I went and done it now,...... Embarassed
Just took a deposit on my trusty 557,......SO, it looks like the Ol' Copper truck is going to be w/o and engine soon,......at least for a little while. Neutral
Got my eye on a nice 598 from a freind,.......but I don't know if I want to go that route or not? What I'd really like to do is build one new from the ground up. The only draw-back is the amount of $$ it takes to do that.
I would like to have something similar to what I had,......a low maintainence deal,....just with more powa. Laughing
A few things are going to be a given,........
Ford Racing A460 Block (4.50" bore or larger)
Trick Flow A460 Heads
Scat 4340 crank w/ 4.5" stroke
Scat H-beam Rods (w/ bolt upgrade)
Wet Sump w/ Kaase Pump
My previous combo put down roughly 850hp/775tq w/ a 557cu in 10.8 to 1, small cam and unported A-460's with an old style FMS/TFS intake (unported as well)
I'd like to gain somewhere in the neighborhood of 200 on both aspects (both hp & tq) and still keep it a relatively low maintainence deal. MAYBE, just maybe set it up to handle a little N2O as well. Wink
Is this a pipe dream,........or is it doable on (somewhat) of a budget?
Any (good) input will be appreciated.
Copperhead
Copperhead
Help with new build? Empty Re: Help with new build?
Post  Copperhead November 15th 2011, 4:27 pm
Ahhh crap,.....I thought I was posting in the Engine Tech forum. Embarassed
Nick, or somebody else that has the capability, please move this to the proper section.
Copperhead
Copperhead
Post  Lem Evans November 15th 2011, 4:39 pm
With ported heads 1,000 + HP is very doable. 588"-598" with good comp ratio.
Post  rmcomprandy November 15th 2011, 4:55 pm
Lem Evans wrote:With ported heads 1,000 + HP is very doable. 588"-598" with good comp ratio.
I wouldn't think it would be low maintenance though.
Post  yellowhorse7 November 15th 2011, 6:10 pm
Just out of curiosity what is your idea of low maintenance?
yellowhorse7
yellowhorse7
Post  bbf-falcon November 15th 2011, 6:23 pm
Is this Big Mike's engine? If so WoW Very Happy
Post  Lem Evans November 15th 2011, 7:37 pm
RPM would be the maintenance factor, which would be the owner/operator's option.
An example would be a 598" A460 engine I was involved with back in april of this year...1,003 HP @ 6,300 RPM...1,033 HP 6,800 thru 7,100 RPM. It's all 1,000 + HP. I.m.o. it's all about how a guy would gear it and where he'd shift it.
Post  Copperhead November 22nd 2011, 9:18 pm
I'm still tossing things around on my new build and I got to thinking about E-85 fuel. Has anyone ever put together a 572 or larger that has broke into the 4-digit hp range on ,..................Corn? Laughing
Copperhead
Copperhead
