New Intake Porting
New Intake Porting
Being the ports on the Mofia intake are slightly narrower than the ports on my Blue Thunder heads should I port match them or just run it, out of the box ? I know this is the only and best intake fdesigned for our style of head. I need to know asap being we are racing Nov. 26 & 27.
Thank you for your input.
Jim
Jim
Re: New Intake Porting
I would not widen the ports on the Mafia intake to the CJ size of your Blue Thunder heads. It actually makes a good anti-reversion step. Just bolt it on and run it. Trim the roof of your CJ gaskets (just a little) with an X-Acto knife.
If the heads are off the engine, then you may want to make sure that the port roof of the heads is as high as the Mafia intake.
Hope this helps,
Charlie
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
» Intake porting
» Intake porting
» intake manifold porting
» D.I.Y. porting of an A-460 intake manifold
» Porting TFS A heads and intake
» Intake porting
