Drag tire tech
+7
nuclearcobra
DFI429
bigblok2000ranger
powerstrokeace
11 posters
Drag tire tech
Here some info from my buddy Carl Robinson @ Mickey Thompson tires
http://www.streetlegaltv.com/features/interviews/drag-tire-tech-tips-with-mickey-thompson/
Ace
Ace
powerstrokeace- Posts : 1496
Re: Drag tire tech
good read
Re: Drag tire tech
That was a good read, especially the part about the wheel screws.
“Performance benefits have been discovered through the use of additional wheel screws. Take an opportunity to notice a small visual detail on your rear tire package. Many of us have looked over pictures of our car and critique the position and shape of the tire. Did you notice that the wrinkles in the sidewall line up with your wheel screws? So from this it was understood that more wheel screws equals less wrap-up in the tire and wheel package. This reduced wrap decreases 60-foot times and driver reaction times.”
Re: Drag tire tech
X3 good read looks like I need to add some tire screws to mine from that article.
Re: Drag tire tech
I run 36 screws per rim...........always have
Re: Drag tire tech
richter69 wrote:I run 36 screws per rim...........always have
Just another part of the HeRo programme...
LOL
Re: Drag tire tech
Guy's feel free to call Carl anytime and ask question that you may have. Just tell him NICKEL sent you. 330-686-3552. this is his direct number. This is the best time of the year to catch him . Normally he out at event doing what he does best and consult. He's also a former chassis builder as well.
Ace
Ace
Re: Drag tire tech
He's the one that came up with the bead lock idea doing thatrichter69 wrote:I run 36 screws per rim...........always have
nuclearcobra- BBF CONTRIBUTOR
Re: Drag tire tech
my rims aint rated for a burnout i dont have near enough screws!
Re: Drag tire tech
notice the SFI sticker................rated for high horsepower.......
Re: Drag tire tech
Did you machine the recess for the rim screws?
Curt- Posts : 2791
Re: Drag tire tech
yes, alumastars have a rolled edge making the screw placement difficult. It was a rig but it worked pretty slick.............I can do awesome things with a drill press lol.
Re: Drag tire tech
i'd think a buncha holes drilled in an sfi high horsepower part would'nt work out too good.never realy thought about it till all the "safety" talk from the nhra lovers................just sayen.richter69 wrote:notice the SFI sticker................rated for high horsepower.......
Re: Drag tire tech
Doug Rahn wrote:That was a good read, especially the part about the wheel screws.“Performance benefits have been discovered through the use of additional wheel screws. Take an opportunity to notice a small visual detail on your rear tire package. Many of us have looked over pictures of our car and critique the position and shape of the tire. Did you notice that the wrinkles in the sidewall line up with your wheel screws? So from this it was understood that more wheel screws equals less wrap-up in the tire and wheel package. This reduced wrap decreases 60-foot times and driver reaction times.”
From Dave Morgans Chassis Seminar, another thing is to make sure the outside and inside screw holes are directly across from one another, so that they do not put a twist in the tire under launch conditions.
racnrick- Posts : 462
Re: Drag tire tech
I just installed tubes in tires with screws i got 32 total in both rims .is that enough?
10in.tire running 1.44 60fts before.tubes and.screws. Hooiser PQT 27x11.50x15
Should i double up on screws
if i decide to go radail tire next tims.do i run the tubes?if.not.wouldnt the air seep oit pf them ?
2fox- Posts : 275
Re: Drag tire tech
Bump will they lose air with out tubes with no.screw or do I need to screw the street radails too.and use tubes don't know help
2fox- Posts : 275
» 1982 mustang big tire drag car
» I'm looking for tire info for drag racing my truck.
» tire size back half frame kits tire width on 70 mustang
» Big tire/Small tire.....
» Tech
» Tech
