I'm looking for tire info for drag racing my truck.
dirt_worker
crittersf1
racinghabbit
looking to 1/8 mile drag my mud truck. looking for advice on what tires to use(size)... 600 hp big block with the rearend spooled. 3.50 gears , C6, truck weights 4800lbs.
racinghabbit- Posts : 575
Re: I'm looking for tire info for drag racing my truck.
Running that anemic gearing you need the shortest tire you can find.
crittersf1- Posts : 521
id prob run something about 26-27 tall... I have 411's and a 29 on mine
dirt_worker- Posts : 535
crittersf1 wrote:Running that anemic gearing you need the shortest tire you can find.
Sorry, I had to lol considering the gearing I run
kjett- Posts : 1169
I agree with the above posts. If you have a bit shorter gear, swap it out. Otherwise, find yourself a short tire to make those 3.50's work better. I currently run a 4.88 gear with a 33" tire...
ThndrChkn- Posts : 2216
The math I did says a C6 with a 2.46 low and 3.5 gear is the same as a 4.88 gear and a glide with a 1.76 low, and a 1.46 second X 3.5 is the same as a glide in 2nd. So I'd run a 30-32" tire and just use first and second in the trans.
schmitty- Posts : 4538
schmitty wrote:The math I did says a C6 with a 2.46 low and 3.5 gear is the same as a 4.88 gear and a glide with a 1.76 low, and a 1.46 second X 3.5 is the same as a glide in 2nd. So I'd run a 30-32" tire and just use first and second in the trans.
Might work on dirt where you can get some wheel speed, but on pavement it will be a total dog at his weight
the 3.50 gear isn't a deal breaker imo...but putting a shorter tire on it will definitely make it work better.
A little more input would be great. I run 16 in rims. what size tires?
» Looking for info on a 1960's FORD drag truck Called "hayhauler"
» 4x4 drag truck 4 link
» Drag truck project
» To screw tires to rim or not and more tire questions... for a 3900 lb truck with a 15 by 10 rim......
» Any info on this truck?
