557 vs 514 weight?
soupbean
557 vs 514 weight?
What do you guys think I can expect in weight reduction going from a dove headed 514 to an a headed 557?
soupbean- Posts : 637
Re: 557 vs 514 weight?
A460 heads weigh that much
res0rli9- BBF CONTRIBUTOR
Id think the manifold would be heavy also on the A460 deal, lot of aluminum there. I think there is only 80 #'s in a iron dove and like a alum cj style head, the a460 heads are bigger...............I couldnt tell ya Lem prolly knows the weight diff............I bet it would pretty much be a wash though.
My old A-429 alum CJ heads were 69 lbs (pair), my new TFS A-460 18 bolt heads ported from Charlie are 88.8 lbs (pair). They both had valves, springs, pushrod plates and rocker studs. More weight with A-460's, buut should have more HP,
racnrick- Posts : 462
racnrick wrote:My old A-429 alum CJ heads were 69 lbs (pair), my new TFS A-460 18 bolt heads ported from Charlie are 88.8 lbs (pair). They both had valves, springs, pushrod plates and rocker studs. More weight with A-460's, buut should have more HP,
D0VE heads are CAST IRON.
The deletion of weight is always more effective then the addition of comparable horsepower. However, the weight difference here would be almost the same yet the horsepower addition in this instance is no where near comparable; being that you should be adding a whole lot more power, lol.
The D0VE heads are about 15 pounds apiece heavier than A460's and the intake manifold difference is about 12 pounds so, you would gain only about 18 pounds total so, if the power was the SAME you would gain.
rmcomprandy wrote:racnrick wrote:My old A-429 alum CJ heads were 69 lbs (pair), my new TFS A-460 18 bolt heads ported from Charlie are 88.8 lbs (pair). They both had valves, springs, pushrod plates and rocker studs. More weight with A-460's, buut should have more HP,
X2
That sucks! I was hoping to shed a few pounds.
soupbean wrote:That sucks! I was hoping to shed a few pounds.
the edel deal is a bout 50lbs lighter ,,,,,,,, lol
Not funny Nicky!
soupbean wrote:Not funny Nicky!
j/k .... i cant wait to see what that 557 does in your stang
I wouldn't sweat the weight, the better cyl head will more than make up for it. It's kinda like an A460 block, yes its heavier...........but its a good kind of heavy............
bruno wrote:soupbean wrote:Not funny Nicky!
I had already started taking pictures of the 562 with me into the bathroom But... I too can't wait to see what this little fellar will do!!!
richter69 wrote:I wouldn't sweat the weight, the better cyl head will more than make up for it. It's kinda like an A460 block, yes its heavier...........but its a good kind of heavy............
Not really sweating it, just thought it might help with that converter situation and ofcourse go even faster! I guess I could go on a diet huh?
Honestly take whatever advice Lenny gave you on the converter deal, IMO its not a place to skimp.
The car as a whole needs to be considered, not just the powerplant.............
richter69 wrote:Honestly take whatever advice Lenny gave you on the converter deal, IMO its not a place to skimp.
Yeah I am beginning to learn that fact. I bought this car "turn key" in Sept. and already have dumped 90% of what I gave for it back into it. It must be fast, it must be competitive, and it must be consistent. Otherwise, whats the point? My wallet isn't very happy right now but it is what it is! Hopefully it will all pay off in the spring. Hell, atleast its keeping me from blowing it in bars
» 429 rod weight
» maybe on here alrady but wondering max bore on an a460 block?
» 1970 outlaw mustang 25.1E good till 2015
» Car weight sbf/C4 going to BBF/PG
» Oil Weight ?'s
» Oil Weight ?'s
