18 bolts for c-heads
badnotch
18 bolts for c-heads Empty 18 bolts for c-heads
Post  badnotch November 26th 2011, 9:20 am
do i have to buy a complete set of sbf head studs to get the other 16 bolts needed to make it 18 per side ? thanks
badnotch
badnotch
http://www.gnlmotorsports.com
18 bolts for c-heads Empty Re: 18 bolts for c-heads
Post  Doug Rahn November 26th 2011, 10:00 am
Probably BF Evans Raceparts can fix you up without buying a whole set.
Post  dfree383 November 26th 2011, 10:03 am
You can get the stuff complete or by the piece froo ARP. Any of the vendors on here should be able to hook you up, Lem, Randy Malick, Dave Mcclain, Etc.
Post  Lem Evans November 26th 2011, 10:22 am
TFS has a kit for the additional 7/16" fastners. TFS-54504304A .
Post  badnotch November 26th 2011, 10:47 am
LEM YOU SURE THEY WILL WORK with the c-head i thought the a head was way shorter ? thanks and cant i just buy them from you Smile gonna need a set of head gaskets again to - pulling motor to make some adjustments
badnotch
badnotch
Post  richter69 November 26th 2011, 11:09 am
so whatcha changin??? Very Happy
Post  Lem Evans November 26th 2011, 11:12 am
badnotch wrote:LEM YOU SURE THEY WILL WORK with the c-head i thought the a head was way shorter ? thanks and cant i just buy them from you Smile gonna need a set of head gaskets again to - pulling motor to make some adjustments
The 9/16" studs are shorter on the A460 heads ......not the 7/16". We have the head gaskets in stock. We sold the last bolt kit that was in stock monday......no big deal can be dropshipped direct to you...About $65 + the ride I think.
Post  badnotch November 26th 2011, 11:21 am
pulling jeff johnson pan off -rear main is leaking Sad
gonna check everything out and do some chamber work, and minor porting and possible compression increase and maybe a tad bigger cam Smile and thats about it then in 2013 season im taking a couple years off and reduing the engine for eith all out motor hp or putting a 106 on it .
not sure
badnotch
badnotch
Post  bbf-falcon November 27th 2011, 12:50 pm
badnotch wrote:pulling jeff johnson pan off -rear main is leaking Sad
not sure
Damn Gerry,Sounds like you have it all planned out Shocked I can't plan whats gonna happen tomorrow Laughing
Post  badnotch November 27th 2011, 5:07 pm
well i need a new cage if i do the 106 so we will see after next year -getting married next year to so im in big trouble
badnotch
badnotch
Post  Nevs November 27th 2011, 11:46 pm
badnotch wrote:well i need a new cage if i do the 106 so we will see after next year -getting married next year to so im in big trouble
Yep, you're screwed! Razz Laughing
Post  res0rli9 November 28th 2011, 3:25 am
Yep, you'll be selling that car then also Razz
Post  badnotch November 28th 2011, 6:08 am
thats not gonna happen she love racing cheers Laughing
badnotch
badnotch
