what aluminum heads would be better than max effort dove heads.
Building a 545 lower end with flat top pistons. full race engine... What heads would you run that would be better than dove max effort heads..?
racinghabbit- Posts : 575
Re: what aluminum heads would be better than max effort dove heads.
Eddy CJ, A429, Blue Thunder A or B, TFS Streets.
schmitty- Posts : 4538
That will also work with my tfs mafia intake
All of the above are direct replacement deals with the same valve layout. If you want to change pistons add the SCJ and P51
Be careful with the Mafia intake. RandyM was in one thread about them, and if I remeber correctly they might have been cataloged wrong, or there was an interchange problem/confusion of sorts. What I am trying to say is, be sure which Mafia intake you have first. Since you said "full race" I was thinking THOR GENII and dual dominators. That may be extra full race though.racinghabbit wrote:That will also work with my tfs mafia intake
supervel45- Posts : 4498
https://www.429-460.com/t20254-mafia-manifold-is-not-what-i-thought-it-was?highlight=mafia+intakeracinghabbit wrote:That will also work with my tfs mafia intake
» 429 dove heads
» switching D0OE-R head to DOVE-C heads
» A429 Heads VS Dove-c Heads
» Dove-c Heads
» Dove-c Heads
