.043 .043 3/16 Low tension rings v/s std tension
.043 .043 3/16 Low tension rings v/s std tension Empty .043 .043 3/16 Low tension rings v/s std tension
Post  tconnection November 28th 2011, 12:11 am
Which tension would be best for my n/a 14:1cr 580ci?
tconnection
.043 .043 3/16 Low tension rings v/s std tension Empty Re: .043 .043 3/16 Low tension rings v/s std tension
Post  dfree383 November 28th 2011, 12:16 am
Are the pistons gas ported? are you running a vac pump?
Post  tconnection November 28th 2011, 12:23 am
Yes they're gas ported and i'm not sure on pump or evac sysrem.
tconnection
Post  dfree383 November 28th 2011, 12:28 am
Id definetly lean towards the lighter oil and back cut rings.
Post  c.evans November 28th 2011, 12:34 am
Well, if you have a consistent machinist who regularly does your hone jobs, and you are sure the rings will hook up and seal, I'd run the low tension rings. If you don't run a vacuum pump, at least run the old tried and true Moroso crankcase evac system from the collectors to the valve covers.
If it's a new guy you don't know anything about, you might want to give a second thought about running std. tension rings.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  tconnection November 28th 2011, 1:08 am
Auctually i have low tension in the mail, total seal classic race #crl-4325-285. I dont know about them having a back cut. The pistons are gas ported.
tconnection
.043 .043 3/16 Low tension rings v/s std tension Empty CRL-4325-285
Post  tconnection December 10th 2011, 9:45 pm
CRL-4325-285,.043 .043 3/16, 4.530 bore. Is anybody running this ring? About how much nos can thay safely handle?
tconnection
