piston rings.. oil ring low tension or standard tension
piston rings.. oil ring low tension or standard tension???
bigunitmudracing- Posts : 159
Re: piston rings.. oil ring low tension or standard tension
It depends on a number of things,,,,,such as vacuum pump or no vacuum pump, and it depends on what grit stone your block is honed with. Crankcase e-vac system or not. If you are going to build a good engine where the rings are hooked up and you're able to keep the cylinder clean and dry, then most of the time you can go with the low tension rings on a good race engine.
Hope this helps,
Charlie
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
Street engine = std. oil rings
Race = low oil rings
This is in the context of I think you have the 1/6-1/16-3/16 ring package.
will the ring chang the amount of vacuum the engine pulls???
its a race engine but it has to pull 15 in vacuum at 900 rpm...
thanks
thanks
The "low tension ring" is referring to the tension of the oil ring expander, so it should not affect the amount of vacuum the engine pulls.
The engine's vacuum is greatly determined by the camshaft and specifically the amount of overlap. Thus widening the lobe seperation angle helps reduce the amount of overlap, and will increase the vacuum.
Hope this helps,
Charlie
Hope this helps,
Charlie
It could a little......it's more about the top ring at that point........not the oil ring.bigunitmudracing wrote:will the ring chang the amount of vacuum the engine pulls???
thanks
Ask the camshaft.
YOU GUYS ARE AWSOME!!! I dont know a lot about what makes changes in an engine. I dont have enough experience...
» WHICH PISTON RINGS?
» piston ring choice and preferred ring seat/breakin time ?
» .043 .043 3/16 Low tension rings v/s std tension
» Low tension oil rings
» Pros and cons for low tension oil rings
