turbo header build Q's
Im building a 545bbf with twin s400 series turbos and need to know what size tubing to use for headers and also what size the hotside pipes should be. thanks
stanggt- Posts : 494
Re: turbo header build Q's
If you are talking about the B/W s400 I think it is a 5" DP and tubes for the headers what heads are you running?
Northwest outlaw- Posts : 962
Most are 5" and they have a different taper than the Precision's and Garrett's. Stepping down to a 4" quickly after the flange is what most do.
NW outlaw can help you on tubing size. The only turbo headers for bb's that I have built were for a twin 91 car and they were 2.25" with a 4" hot side and 4" after turbo but the exhaust was only like 18" long each.
whatbumper- Posts : 3024
yes, the exaust is 5" but what size pipe should I run from headers to the turbos? 3" or 3.5"?The heads are SCJA Kasse heads. Thanks Outlaw, was wondering if anyone could help me here.Northwest outlaw wrote:If you are talking about the B/W s400 I think it is a 5" DP and tubes for the headers what heads are you running?
I'm doing a single turbo 547 and decided to use 2", 14 gauge primary tubes to 2.5" collectors combining to a 3" as it goes to the turbo. I'd think that a similar setup should be fine for you too. All of that seems very small, but the exhaust gauge is under pressure.
Have a good day!
Michael
Have a good day!
Michael
96Mustang460cid- Posts : 154
» 750hp turbo build
» Doing a sbf turbo build does anyone want to
» All forged 466 efi build with turbo later
» What's your "as stock as possible" Turbo build?
» TURBO FORD BUILD
» TURBO FORD BUILD
