trans filter hook up
trans filter hook up Empty trans filter hook up
Post  GT300TD December 8th 2011, 6:13 pm
Is it best to hook up the a transmission filter to the return line or the outlet line?
Thanks.
GT300TD
trans filter hook up Empty Re: trans filter hook up
Post  bbf-falcon December 9th 2011, 3:58 am
I never have ran a external filter.Just the one in pan is all.
Post  the Coug December 9th 2011, 7:55 am
bbf-falcon wrote:I never have ran a external filter.Just the one in pan is all.
Rick some people try to complicate things, I agree with you just put the internal filter in.
Post  crittersf1 December 9th 2011, 8:54 am
I always put them in the return
crittersf1
crittersf1
Post  GT300TD December 9th 2011, 8:56 am
I found it on the shelf the other day, forgot I had it. My buddy suggested I get it when I bought the trans cooler a while back. I figured it's paid for so I might as well use it. I was thinking of running it into the return line going into the back of the trans. Overkill, maybe, but it will be easy to change. It also has a transmission temp gauge settup with it.
Thanks.
Edit... thanks for the confirmation, critter.
GT300TD
Post  Oldani December 11th 2011, 1:26 pm
If you feel the need to add in a secondary filter (which I personally don't) put it in the line from the trans to the cooler; not the line from the cooler to the trans. Why? Because this will keep the small metallic particles from getting into and settling in the cooler. But make sure the filter will flow sufficently and that you check it at regular intervals.
Oldani
Oldani
