I want to hook my pc to my tv
I want to hook my pc to my tv Empty I want to hook my pc to my tv
Post  OldRedFord October 18th 2009, 5:52 pm
To do it do I just need one of these?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3012897&CatId=1408
OldRedFord
OldRedFord
I want to hook my pc to my tv Empty Re: I want to hook my pc to my tv
Post  jasonf October 18th 2009, 6:44 pm
What kind of TV do you have and what kind of video output on the computer? IF it is a new tv there should be a computer input (either 9 pin d-connector or the digital equivalent). I tried the RGB cable like you have posted and I could never get it to work with computer.
Post  OldRedFord October 18th 2009, 6:52 pm
I guess I should have added a bit of info. Its a Dish Netowrk tv that I traded some work for. The computer has a VGA output. Now that I have looked more it looks like I need a converter thingy, or I could just buy a video card. But I am limited with video cards cause all I have are plain ol PCI slots. Something with S-video or component out would work I bet.
OldRedFord
OldRedFord
Post  jasonf October 18th 2009, 6:57 pm
So what kind of inputs does the tv have? Just s video and component?
Post  OldRedFord October 18th 2009, 7:14 pm
S-video, component, and composite.
Looks like buying a PCI card with the output I need would be the cheaper route.
OldRedFord
OldRedFord
Post  OldRedFord October 19th 2009, 1:16 am
Well here is the deal. The computer just has the on bored video right now. The tv has all this stuff on the back. http://www.sadoun.com/Sat/Products/Dishnetwork/TV/HD34-Back-Panel.jpg
From doing some reading up, the adapter I showed won't work. Correct me if I am wrong, but computer video out is in the form of RGB colorspace so I would need a card that would put out YPbPr or get a converter thingy that seem to run about $60 or so.
So I am looking at buying this card http://www.newegg.com/Product/Product.aspx?Item=N82E16814130188 and then a S-video cable. http://www.svideo.com/4pinsvideo12.html
OldRedFord
OldRedFord
Post  jasonf October 19th 2009, 9:11 am
With that video card you should be able to use the DVI output and go into the tv's DVI input. This would take a standard digital monitor cable which you might already have.
It will also be a digital signal vs an analog signal like the S video. I built my last computer using EVGA components and they have an excellent website/forum for technical help. You might want to try and post over there before you buy just to confirm everything but it looks like it should work to me.
http://www.evga.com/forums/
Post  DFI429 October 19th 2009, 10:38 am
x2 on the DVI if you can use it - Digital! That or the component.
Don't even bother with composite or S-Video - they're the worst picture quality, and low resolution.
I use a DVI to HDMI cable between my laptop and my 46" Samsung - makes Flight Simulator X look awesome Very Happy
DFI429
DFI429
Post  jasonf October 19th 2009, 1:31 pm
DFI429 wrote:I use a DVI to HDMI cable between my laptop and my 46" Samsung
Just one other note. DVI and HDMI are the same format so there is not compatibility issues when using the two together.
