Help with a gear ratio
2650 lb car, 605 with A460's and a single dominator...Cam is .848/.828 and .284/.302 @ .50 installed on 115..Car has a glide with 1.80 set and 3.89 gears out back....Gonna spray anywhere from 150 to 300 on it....Is the gear ratio close or will i need a gear change...Thanks guys ...Henry
Henryslx- Posts : 89
Re: Help with a gear ratio
how tall's the tire?
Dang it...I forgot the most inportant item....32 x 10.5dfree383 wrote:how tall's the tire?
1/4 or 1/8 mile?
how tight is the converter?
Mainly 1/4 mile, but alil heads up 1/8 mile.....37-3800 on the transbrake...
I think the 3.89 will be pretty close on Mr. Frosty.
I hope so....dfree383 wrote:I think the 3.89 will be pretty close on Mr. Frosty.
good place to start anyway,if the converters up to it.lol
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» Pro Stock Trans gear ratio / Rear Gear
» Gear ratio help
» C6 Low Ratio Gear Set
» gear ratio/gas mileage
» Gear ratio help
