need a different trans
466cj
BigDave65
hpwdboss1
need a different trans Empty need a different trans
Post  hpwdboss1 December 12th 2011, 1:18 pm
We have been looking at transmissions to use in our tractor. We cannot use manual/cluth setups, MUST be auto with converter. To achieve the gearing we desire, we need a trans with a low gear that is between 3 and 3.5:1 and allows an upshift into a 2.5:1. A 545 allison is 3.45(1st) then 2.25 (2nd) which is just to fast. It is not economically feasible to change rear end gears, and we cannot have supplemental gear boxes. We make <500h.p. maybe 600 ftlbs, max 6000rpm. Tractor weighs 5500 with driver.
Does anyone know of a trans with a ratio like this? Or have ideas that might be of help ? Heck, can a C6 be built to achieve these ratio's?
Perry
Last edited by hpwdboss1 on December 12th 2011, 1:23 pm; edited 1 time in total (Reason for editing : added info)
hpwdboss1
hpwdboss1
need a different trans Empty Re: need a different trans
Post  dfree383 December 12th 2011, 2:46 pm
New Ford 6 speed automatic? Not sure how economical they are over getting new rear gears.....
Post  BigDave65 December 13th 2011, 1:25 am
Could you use something like a LencoDrive or Lenco/Bruno set up?
BigDave65
BigDave65
Post  466cj December 25th 2011, 6:04 am
Ford Mustang 5R55S should be
1st- 3.25
2nd- 2.44
3rd- 1.55
4th- 1.00
5th- .75
Although some sources list different ratios...
466cj
need a different trans Empty Re need a ...
Post  hpwdboss1 December 25th 2011, 3:41 pm
I'll do some reading and see what I can learn about them. We don't break C6 trans as it is, just need the diff ratio's. I'll need to find out about how it will stand up under our conditions, etc.
Thanks for the direction!
Perry
hpwdboss1
hpwdboss1
Post  Diggindeeper December 28th 2011, 11:37 pm
I got a 44 Massey rear I could lend you. It would fix your issue Very Happy You won't break it.
In all honesty I thought I had the answer for you but I read your post about your rules and my idea was out
Diggindeeper
Diggindeeper
Post  the Coug December 30th 2011, 12:23 am
get you a Bruno and put a Lenco behind it that way you have a converter and can row the sticks.....I am pretty sure they will get you any ratio you want....
Post  DILLIGASDAVE December 30th 2011, 10:08 pm
One downside with a Bruno/Lenco combo is they will chew up some power. One good point is on each gear change the Lenco can be shifted softer/harder depending on how you adjust each section's shifter tower height.
Post  QtrWarrior December 30th 2011, 11:39 pm
DILLIGASDAVE wrote:One downside with a Bruno/Lenco combo is they will chew up some power. One good point is on each gear change the Lenco can be shifted softer/harder depending on how you adjust each section's shifter tower height.
The Bruno /Lenco doesn't eat that much. My old dragster only went .02 faster after I changed to a 'glide and that was probably from the 30 lb weight difference
QtrWarrior
QtrWarrior
Post  DILLIGASDAVE December 31st 2011, 12:25 am
Might be a door car vs dragster thing.
On a nitrous door car I worked on swapping back & forth between a Bruno/Lenco 3 spd vs a 'glide, the glide was always around a tenth quicker & about 3 mph faster than the B/L. The B/L did however have a slight advantage in the first 60ft, probably from the steeper 1st gear.
need a different trans Empty Need a different...
Post  hpwdboss1 December 31st 2011, 11:44 am
I am bound by rules to an "automotive" trans so no good on Bruno-Lenco set up. I don't have any strength /durability problems w the C6, just need to shift up to about a 2.5:1 to come out a little bit harder. The 2.5 gives me all the tire speed our combo can pull.
Thanks again
Perry
hpwdboss1
hpwdboss1
