trans/t-case mounts with motor plates
anyone have pics of their trans/t-case mounts on trucks with front and mid plates? I'm more specifically looking for pics other than factory crossmembers.
Anyone using anything other than the factory intermediate housing mount
Is it better to hard mount the crossmember and soft mount the trans or softmount the crossmember and hard moun the trans? Soft mount both? If I soft mount the crossmember how much does it need move?
IcallhimGeorge- BBF CONTRIBUTOR
Re: trans/t-case mounts with motor plates
I don't have pics but in my mud truck I had front and mid plates and used the factory trans mount and no transfer mount. I left the bolts on the trans mount a little loose(using lock nuts) allowing it to move slightly when the chassis twisted but supported the weight of the trans and transfer case(205)
lghting94- Posts : 762
sounds like soft mounting the crossmember and the trans would be the best bet.
If you have any chassis flex at all run a flex mount on the tranny. I love it when guys brag that they have so much hp that they broke their bell housing on a truck with plates and then a solid tranny mount.
mudtrucker- Posts : 160
Are there any options other than a factory rubber mount? I havent seen any poly trans mounts.
mounts
On my pull rig I have everything rubber mounted, I used the old 55 chevy biscut mounts,Napa part number 6021044... they are basically a round donnut, 1 inch thick with a 1/2 hole....compressed they are about 3/4".....A little flex saves parts..
samiam- Posts : 240
» trans/t-case mounts with motor plates
» FS: Motor Plates & Mid-plates -- BBF & Hemi
» Mounts or plates? BBF in Fox body
» Tans Dapt motor mounts
» 4R100 trans case or core
