Will it pull
+11
Barney
whitefield
Diggindeeper
zbob
jcoxracing
Henryslx
quick 52
15 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Will it pull
have a 1500 suburan with 5.3 will it pull a 24' enclosed trailer with a 4000# car in it
quick 52- Posts : 612
Re: Will it pull
I have a Tahoe with a 5.3 and my trailer is 28 ft... car is not as heavy but mine pulls fine, jus cant get nasty with it on a grade...
Henryslx- Posts : 89
Re: Will it pull
gonna get hairy ...but yes it will pull it
Re: Will it pull
not very quickly, or safely, but it should get it there..............
Re: Will it pull
My brothers 5.3 burban struggled with a 20 ft. trailer with a 3500 lb car. I hope you have load levelers, sway bars, and, ride rite bags.
Good Luck
Justin
Good Luck
Justin
jcoxracing- Posts : 282
Re: Will it pull
it does have autoride and seem to pull my open trailer ok with a 4000# car
Re: Will it pull
depending on the trailer, and the amount of stuff crammed in it..............I'll venture a guess mine is well over 11k fully loaded, hell maybe more. The added weight will tax the trucks suspension, the increaed wind drag will tax the powertrain. It can be done but man your in for a white knuckle ride. How far do you tow to the track?
Re: Will it pull
Don't forget about the brakes or rather lack of brakes
John Myrick- BBF CONTRIBUTOR
Re: Will it pull
the trailer has brakes is there more to it then that. should be pulling around 7500# trailer and car
Re: Will it pull
my 5.3 silverado pulls my car. BUT it has the 6 speed tranny, ten ply Firestone tires, a open 14ft light weight trailer and the car weighs only 3050. i also putz along like mr magoo....fwiw, bobn
zbob- Posts : 271
Re: Will it pull
5.3's barely have enough power to get out of their own way. Also better check for coolant in the oil if you get there.
Diggindeeper- Posts : 800
Re: Will it pull
I've got a 2011 burb with the 5.3 and it has a hard time pulling my 25' boat around FWIW
schmitty- Posts : 4538
Re: Will it pull
I would worry about the transmission ! Those things are weak and junk ! If it has the 4L80 you are in good shape but I doubt that you have the 4l80 with a 5.3.
whitefield- Posts : 2244
Re: Will it pull
My 2005 Silverado 5.3 w/ 4.10 gears ran 15.30s and pulled a 24 ft 75-80 mph all day. In fact speed wise it pulled better than my Excursion, control and brakes not so much.Diggindeeper wrote:5.3's barely have enough power to get out of their own way. Also better check for coolant in the oil if you get there.
Re: Will it pull
I use to have a silverado 5.7 4x4 z71 and it wouldn't pull the hat off a sick Whore. all it would do is 55mph loaded out of OD... I wouldn't walk across the street to pee on it if it was on fire......
the Coug- Posts : 3055
Re: Will it pull
My 2010 F150 will tow that thing just fine, but slower than Fabio....
Re: Will it pull
Coug,
Wouldn't pull the hat off a sick Whore.......that is a weak S.O.B.
You crack me up.
Thanks,
Gord
You crack me up.
Thanks,
Gord
gdog- BBF CONTRIBUTOR
Re: Will it pull
dfree383 wrote:My 2010 F150 will tow that thing just fine, but slower than Fabio....
I see our tow rigs and race cars have something in common...................
Re: Will it pull
richter69 wrote:dfree383 wrote:My 2010 F150 will tow that thing just fine, but slower than Fabio....
My little 427 will blow your car away........
Re: Will it pull
dfree383 wrote:richter69 wrote:dfree383 wrote:My 2010 F150 will tow that thing just fine, but slower than Fabio....
even at your weight Im not so sure................
Re: Will it pull
Bring it....... 2012 Bash I'll grudge race you with it.
Re: Will it pull
you better leave now it will take you 5 months to drag it there lol
Re: Will it pull
richter69 wrote:you better leave now it will take you 5 months to drag it there lol
And we all know you won't show any way...... You'll make up some kinda excuse about the cost of fuel, racing somewhere else, The Wife wont let you, Dano wants to beat you up........
Re: Will it pull
hell nobody showed last year, they all had excuses.
Page 1 of 2 • 1, 2
Page 1 of 2
