Danny Bee BBF belt drives
+6
DNETT1727
crittersf1
10 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Danny Bee BBF belt drives
Google is your friend. I found his site. thanks
Not sure his will work as it's designed for a short snout
thanks
Jon
thanks
Jon
G-Code- Posts : 193
G-Code wrote:Google is your friend. I found his site. thanks
thanks
Jon
I matters also where tdc is on the dampner.
my guy is pretty resourceful, he made his own after seeing the other one:
Jon
G-Code- Posts : 193
Are there provisions for an oil dip stick? As I don't have one on the pan.
Tore
Tore
Tore- Posts : 865
That is sweet what do they help do ?
MustangDan- Posts : 140
Buy one , guys…..The advantages are endless. You’ll never run a chain again.
maverick- BBF CONTRIBUTOR
Lem, Ya got replacement belts in stock? $$?
I run a Danny Bee belt drive on my 521. There were a few problems that I had to deal with. First problem was that the snout on the crankshaft was too big to fit in the lower pulley. I measured it and found out that the belt drive pulley was correct, but the crank was oversize. It wasn't possible to grind down the crank snout so I had to bore out the lower pulley.
Also ended up making my own TDC pointer. I had ATI move the TDC mark over to the driver's side and then fabricated a TDC pointer.
Last issue I had was that there was no easy way to remove the upper pulley from the cam. I had to design and fabricate a puller.
AndyF- Posts : 49
Page 2 of 2 • 1, 2
» Need good year part number for danny bee belt drive belt asap?
» New Innovators West Belt Drives
» WANTED DANNY BEE BELT DRIVE 429 460
» Danny Bee Belt Tension
» Danny Bee Belt drive Sale !
Page 2 of 2
