Danny Bee Belt Tension
First time setting one up on my BBF. I am seeing hints of where people are using a chromatic tuner to capture the frequency to tune the belt tension. for example, I tested one setting and it showed as a G3 note, which equated to 186Hz. I feel this may be a little tight, but looking for answers from those with experience!
Thanks,
Tony.
Thanks,
Tony.
Tonyb- Posts : 9
Re: Danny Bee Belt Tension
Tonyb wrote:First time setting one up on my BBF. I am seeing hints of where people are using a chromatic tuner to capture the frequency to tune the belt tension. for example, I tested one setting and it showed as a G3 note, which equated to 186Hz. I feel this may be a little tight, but looking for answers from those with experience!
Thanks,
Tony.
Just make sure it is not to tight, hot.
BOSS 429 likes this post
Straight edge on drivers side of the belt .......................... MOVING IDLER UP TOWARD CAM GEAR,NOT DOWN
To do this you will be pulling downward on wrench
WITH ALUM BLOCK BELT SHOULD MOVE .080 TO .120 THOU
WITH IRON BLOCK .050 TO .080
THEN TORQUE NUT TO 60 TO 65 FOOT LBS WITH BLUE LOC TIGHT
LITTLE NUTS ON CAM GEAR TO 18 TO 22 FT LBS WITH BLUE L/TIGHT
Belt will tighten up when warm
-Rich
-Rich
BOSS 429- Posts : 2372
» Need good year part number for danny bee belt drive belt asap?
» Danny Bee belt drive
» Danny Bee belt alignment
» Danny Bee BBF belt drives
