I need sbf crank help
bosshoss
Page 2 of 2
Page 2 of 2 • 1, 2
Re: I need sbf crank help
whatbumper wrote:Didn't have time to make any calls today but may have a hit on a scat crank built to this block in world product specs. 3.47 stroke
Damn and I was wanting to build a destroker to turn 9000+ rpms
the Coug- Posts : 3055
In an 8.2" deck "World" block with 302 mains and 4.125" bore, I have used a Cleveland crank with reduced O.D. counterweights and cut down mains, (which isn't necessary for you), and offset ground stroke to 3.600" with Toyota rod sizes and 5.290" long SCAT rods with custom pistons for the smaller pin diameter. The CD at 1.11" was actually taller than a 347 CD at 1.09".
It was 385 inches but, looked like a 302 on the outside.
With this "World" block I wouldn't have needed to reduce the main sizes, LOL.
What about bearing spacers and a regular 302 stroker crank?
IDT-572 wrote:What about bearing spacers and a regular 302 stroker crank?
I don't know if they still make it but the old bearing kit was $599 plus the machine work to install it. I was told that it was not as simple as the chevy spacer kits.
whatbumper- Posts : 3024
Page 2 of 2 • 1, 2
» differences in 68-69 crank pulley to 70 and up crank pulley for Lincoln with crank PS
» Scat/Motorsport 4.300 cast crank
» WTT hawks/RPM 4.5 stroke cast crank for 4.150/514 crank
» BBF Crank
» BBF Crank
Page 2 of 2
