Im going bigger, how much carb
samiam
steppin up 598, 16 + comp. TFS A460 Heads 2.35 int. 1.88 ex. A460 single intake. 264 268 @ 050 .785 .805 lift on 110 cntr..................... where to start on carb size for Alcohol...................
samiam- Posts : 240
Re: Im going bigger, how much carb
It can be done with a carb, but if you want all there is to get put injection on that deal. An alky carb is gonna be hard pressed to keep enough fuel in that thing. Or put 2 alky carbs on it.................I'd still sway towards the injection, or a big ass gas carb on Q16................
why such a small Cam???
the Coug- Posts : 3055
good point coug
go injection on the CID if you are not already setup for alky the cost want be much different time you buy everytrhing you need for a alky carb setup
with that small a cam what is this for a RV.....
I was wait'n on someone to pickup on the cam
4speed- Posts : 127
that's smaller of a cam my buddy with the a headed fairmont runs, its a 521 and it don't run for shyt..............its also on meth but its injected.........the injected meth aint the problem lol.
he must have just had it from some other build but it is definately not big enough for a 598 A headed deal what he needs is a custom cam....
reply
yep that is a cam I already have, so besides the cam,,,, I was wondering about how much carb
samiam- Posts : 240
Quick fuel 1250 or 1450
1450 it is
thanks, now how about some cam specs. this is for the truck pulls
samiam- Posts : 240
If you have to run a single carb get with APD, its nothing againt QF as they are awesome carbs, but in the big alky carb variety APD has that deal figured out. Plus them trick alum QF bowls dont get along well with alky, dont ask me how I know lol.
samiam wrote:thanks, now how about some cam specs. this is for the truck pulls
You are 20* or more off on the intake and over 30* on the exh.
Also, a lot wider LSA + needs more lift.
Cam talk
Lem Evans wrote:samiam wrote:thanks, now how about some cam specs. this is for the truck pulls
Ok so I been lookin at profiles, whats your thoughts... 280* 288* @ .050, .800 .825 Lift 114 LS
and I do appreciate the input. Sam...
samiam- Posts : 240
» Bigger carb or bigger headers opinions needed
» Beginner tunning questions.
» 1250 or bigger carb.
» WTB a 3 circuit 1250 carb or a lil bigger
» What size carb?
» What size carb?
