What size carb?
What size carb? Empty What size carb?
Post  capncruncher1965 January 17th 2016, 8:57 pm
Guys i have  472 dove heads 2.19 and 1.77 valves ported heads Victor intake with a scotty custom ground cam right now I have  a 750 quick fuel carb. It works great but my buddies say I need a bigger carb what you guys think
capncruncher1965
capncruncher1965
What size carb? Empty Re: What size carb?
Post  dfree383 January 17th 2016, 9:23 pm
A 950 or 1000hp will wake it up.
A 1050 dominator is even better but you'll either need to modify or change the intake.
This is provided it's not a 8:1 2.56 geared 7000# Lincoln with a stock convertor.
Post  billandlori January 17th 2016, 9:34 pm
I am thinking about going to a 1050 also, do the Quick Fuel 1050cfm 4150 carbs work close to a dommy? http://www.summitracing.com/int/parts/qft-rq-1050-an/overview/
I am running a Performer RPM manifold right now. If I go to a Dommy I will need a manifold too.
Bill
Post  dfree383 January 17th 2016, 9:43 pm
billandlori wrote:I am thinking about going to a 1050 also, do the Quick Fuel 1050cfm 4150 carbs work close to a dommy? http://www.summitracing.com/int/parts/qft-rq-1050-an/overview/
Bill
My experience with the big 4150's has always been that they leave power on the table compared to the dominators. But in some applications a dominator just isn't practical or even alowed by some rules.
Post  billandlori January 17th 2016, 9:55 pm
Bill
Thanks Dave.
It will get some street use, there is a lot of options for the dominator. Lots of studying!!
Bill
What size carb? Empty i thought I needed a bigger carb
Post  capncruncher1965 January 17th 2016, 11:43 pm
A friend who owns a speed shop got me the 750 but i told him i wanted a 950 just a mistake. I have a holley 950 base can I just buy a 950 QUICK FUEL MAIN body and put it together?
capncruncher1965
capncruncher1965
What size carb? Empty Carb main body
Post  manofmerc January 18th 2016, 6:31 am
You shouldn't have a problem using that baseplate to build yourself a 950 .Quickfuel can provide a main body .Just ask them for jetting details .My situation was opposite .I had a 950 main body left over and some metering blocks off an old 830 .Bought a new baseplate and some other parts new carb to use .If you go to Proforms website pull up their 950 carb for jetting and air bleed details .Your engine will love the 950 .I put mine on my 427 merc comet .It ran better than the 750 I had on there .Good luck Doug
manofmerc
