carb size
carb size
my build:
545 forged crank/ flat top pistons / P51 heads out of the box / 2.1/4 headers / cam specs: solid roller duration @ .020 306 I 322 E 110 cl
roller rockers / pistons are .010 down in the hole.
ok now down to what I need advice for. I have an SV1 carb 1400 cfm that I need a home for. Will this carb be too big? I also have a 1250 alky carb I could use.'
which should I use?
which should I use?
Larry Williams- Posts : 884
Re: carb size
what is the application, strip only ?? street/strip , bracket or class ??,
in any case a dommy for sure, i would want a 1150 or 1250 on the fuel of your choice
jc10000rpm- Posts : 193
Re: carb size
I'd try that sv1 since you already have it. Why not?
norm- Posts : 260
