Crane valve spring??
There was a post awhile back with the part # for a single valve spring and retainer used with a Crane cam H-288-2 (.522/.530 lift).
I did a search for the post and had no luck
I'm doing a D3 headed build and the single spring will save some machining.
mike
mike
f250mike- Posts : 628
Re: Crane valve spring??
The ford racing A50 Springs and retainers should work.
dfree383 wrote:The ford racing A50 Springs and retainers should work.
X2 ... they will work with even more lift, too if you wish to increase rocker ratio.
Thanks guys!!
Randy are you still selling the HS pedestal mount rockers?
I'm building this 466 for a friend and those rockers will save him some $$-vs- purchasing rockers,studs,guideplates and pedestal machining cost.
mike
mike
f250mike wrote:Thanks guys!!
mike
YES ... send a PM if your interested.
Randy, I'll talk to my buddy and will get with you.
mike
mike
» Affect of valve spring install height on spring rating..
» Valve spring ?
» valve spring reccomendation
» Valve spring
» Valve spring cup
» Valve spring ?
» Valve spring
» Valve spring cup
