first build lots of ?s
this is my first build,
this is the build plan so far
i have a block is d1ve aa bored .040 c8 heads
carb-was planning edel performer series carb
inatake manifold-edelbrock performer rpm
ignition-msd-6a ignition control with msd blaster 2 coil
cam- comp cams hydrolic xtreme energy xe 274h
is this a good build for a performance street motor so far?
also why doesnt the edelbrock performer carb work on the performer rpm intake manifold
and i read on here about weind 8012? i think you guys said it was a lil better than the performer rpm
my teacher said that when people are building good performance motors they dont really use edelbrock carbs why is that and if so what carb should i use and would it work with the performer rpm intake
and will the 800cfm be too much i originally planned on using the performer 750 carb but it doesnt have a 750 in the thunder
what valve train set up should i use (springs lifters push rods etc.)
are rollers worth the extra money
or should i just scrap all this and start from scratch again
and please dont send me to another site thhis is the third one ive been sent to
jlang- Posts : 2
Re: first build lots of ?s
What is the motor going in?
What are your goals/expectations for this car?
What is your budget?
Nothing really wrong with either intake manifold, but depending on engine size and operating range of motor, the Stealth may be a better choice, or may not.
The Eddy carbs are not as much of a performance carb as the Holley based stuff. Depending on goals, a larger carb may be required to feed your mill.
schmitty- Posts : 4538
its going in a 56 ford f250 (3/4ton)
and im trying to build a badass l street motor
i have a lil money but not an unlimited supply
jlang- Posts : 2
Just my $.02
In my experience, Edelbrock carbs are only good for those that don't want to do alot of adjusting/tuning and want better gas mileage. I agree that for a good mean street motor, a Stealth is the way to go.
MeJay Racing- Posts : 4
schmitty wrote:What is the motor going in?
I agree with Rob... I'vs had several streetable BBF's and the Stealth is definitely your best choice, unless hood clearance is going to be a problem, but I see in your case it won't be... The Edelbrock carbs are for show cars in my opinion... An 800cfm carb won't be too big... In my opinion, that's the bare minimum you or anyone should put on one of these engines... I don't know what you altitude is, but up here in the nose-bleed state, I've run 850+ with no issues on the street... A lower altitude may require less...
Good luck,
Doug...
ThndrChkn- Posts : 2216
x2. Stealth is a good call. Scrap the edel carb idea if you're looking for more than just cruising & shows. A Holley 850-950cfm dp ought to do it. After making the change to solid cams years back I'll never go back to anything hydraulic IMO. I'd slide a flat tappet solid in there. Something with spec's recommended by the guru's on the site. I like rollers (I run one myself) but I'm not so sure about the benefit's being worth the money on this build. Some guys say the rollers are more prone to failure in something that's going to see a lot of street miles.
4thHorseman- Posts : 400
» My build.....not done yet, but damn close! lots of pics!
» E4OD build reccomendations for a 79 f150... first transmission build, no ideah what I'm doing
» No rules BBF nitrous build - Let's build it
