bbf in fox with stock K memeber ?
bbf in fox with stock K memeber ? Empty bbf in fox with stock K memeber ?
Post  2fox January 14th 2012, 6:53 pm
Do you need.spec.motor mounts or headders ?
2fox
bbf in fox with stock K memeber ? Empty Re: bbf in fox with stock K memeber ?
Post  dfree383 January 14th 2012, 6:58 pm
Bob at D&D makes a nice Kit with everything you need. He been making the kits forever and is a great guy to deal with and the service dosen't stop once you buy a kit.
http://ddautospec.com/
Post  BOSS 429 January 14th 2012, 8:20 pm
2fox wrote:Do you need.spec.motor mounts or headders ?
hooker makes a header,and a motormount
ive done a few with stock k men,works fine
Post  2fox January 14th 2012, 11:25 pm
the motor mounts.bolts.to the.stock k member or motor plate?
Witha.557 motor.Re.those.motorenoigh ?
2fox
Post  Mike R January 16th 2012, 8:25 pm
dfree383 wrote:Bob at D&D makes a nice Kit with everything you need. He been making the kits forever and is a great guy to deal with and the service dosen't stop once you buy a kit.
X2, Bobs a great guy to deal with. If you have questions, he's got the answers.
Post  BOSS 429 January 16th 2012, 8:49 pm
there mounts bolt on the block,and to the frame horns on the kmember, best bet is to call hooker, or d and d and talk to them,then you can pick which ever you feel is a better deal
Post  2fox January 16th 2012, 11:19 pm
Thanks everyone
2fox
Post  2fox May 15th 2012, 7:02 pm
Has anyone had a bbf With alum heads in a fox with 4cylinder coil springs with 1 coil off on stock KMember if so does it sit low in the front? Or do I need.stiffer coil.springs? Thanks
2fox
Post  dfree383 May 15th 2012, 11:11 pm
Low..
Post  Mark Miller May 15th 2012, 11:55 pm
2fox wrote:Has anyone had a bbf With alum heads in a fox with 4cylinder coil springs with 1 coil off on stock KMember if so does it sit low in the front? Or do I need.stiffer coil.springs? Thanks
I have a BBF in my car with Aluminum heads and stock 4 cylinder springs don't cut them leave them stock.Here's a picture of my car with Aluminum headed BBF and stock un-cut 4 cylinder springs,Later Mark.
bbf in fox with stock K memeber ? MarkMillers560
Post  2fox May 16th 2012, 11:12 pm
I already cut them. But I got a front set of my 03Cobra stock ones I took off . Should I use them? If so do I need to cut them any? Thanks
2fox
