A460 block problems
+7
Barney
2fox
michealj
11 posters
A460 block problems
I have a new A460 block tried to check for main bearing clearance and all bearings fit except
for thurst cap and dowels wouldnt line up the bearings are clevite H just woundering if anyone
else has had this problem. If i need to use other type of bearing??
michealj- Posts : 78
Re: A460 block problems
What Part Number? Pics?
Whats the.cheapest aftermarket block yoy can buy .that at least has a. 4.500 bore or larger?
2fox- Posts : 275
Eliminator Sportsman Block, and he A460 are priced pretty similar.2fox wrote:Whats the.cheapest aftermarket block yoy can buy .that at least has a. 4.500 bore or larger?
2fox- Posts : 275
michealj wrote:I have a new A460 block tried to check for main bearing clearance and all bearings fit except
the little notch in the block,and sometimes the cap need a little filing, i've seen this more then once,its no big deal,i use to file the bearing,now i do the block
BOSS 429- Posts : 2372
As has been said ... a professional engine builder would probably just grind the slot in the block or cap to accept the bearing tang.
It's all about the snake handlin'...............
Whats.the.biggest stroke that can fit.in a.stock.460.block ?
2fox- Posts : 275
2fox wrote:Whats.the.biggest stroke that can fit.in a.stock.460.block ?
I believe this question should be a completely new thread to not morph this thread...?
a little time with the "search" function.rmcomprandy wrote:2fox wrote:Whats.the.biggest stroke that can fit.in a.stock.460.block ?
Dam i join a site..all going good.then someone.always.have to bitch aboit.something am so sorry to have piss you all off i got m/s is.this.is how.you.treat.new a new comer..juststickitthen.
2fox- Posts : 275
2fox wrote:Dam i join a site..all going good.then someone.always.have to bitch aboit.something am so sorry to have piss you all off i got m/s is.this.is how.you.treat.new a new comer..juststickitthen.
Start a new thread and ask a question...
2Fox:
Chill out, buddy - nobody's pissed at you (yet). Keep coming back with responses like that, and you will turn everybody against you. Your question about what's the biggest stroke you can put into a 460 block is in no way relevant to the original post, so - chill and create a new post to ask your question, or as was suggested - use the search function. relax, and enjoy - it won't hurt a bit.
Wayne (SAWDOFF) Pearce
Wayne Pearce- Posts : 658
Was this block prepped and checked by a machine shop?
jbozzelle- Posts : 3705
Yea,like's been said,don't take it personal. Think about it this way,if you had ask that same and it was going real well and you were getting some good responses.Then someone ask's a about a A460 block and the thread turns completely around in a new direction. Thats why the guy's suggest a new thread be started. Many times the thread goes completely off camber if you don't police it. We're not upset at you,so just start a new thread and get the answer you really want. "Peace brother"
» Cometic MLS head gaskets
» distributer block hole is too small on an A460 block
» Differences between stock type block and the a460 block?
» wanted a460 block or eliminator block.
» wtb A460 block or Eliminator Block
