Q16
+19
5pointslow
papamoe
Wheelie58
bigblok2000ranger
yellowhorse7
KY JELLY
Barney
samiam
23 posters
Page 1 of 3 1, 2, 3  Next
Q16 Empty Q16
Post  samiam January 15th 2012, 8:19 pm
I was wondering about Q16. in my pulls class, Methane or alcohal fuels are not allowed,, will Q16 get me disqualified ?
samiam
samiam
Q16 Empty Re: Q16
Post  richter69 January 15th 2012, 8:26 pm
Its got unicorn tears and the sweat from Chuck Norris' balls in it............. Razz
Its an oxygenated fuel, to my knowledge it does not contain nitro or methanol, they should be able to tell you if its legal or not, if I ran gas this would be the stuff I would run though.............
Q16 Empty Re: Q16
Post  bbf-falcon January 15th 2012, 8:35 pm
Different pulling associations have different rules according to where you pull,but my friend is allowed to use it here. It really works Shocked
Q16 Empty Re: Q16
Post  Barney January 15th 2012, 9:04 pm
We run Q16 in a few. If your class allows it and you have the compression it will be worth some power.
Barney
Barney
Q16 Empty re
Post  samiam January 15th 2012, 9:20 pm
13.75 comp. .. is that enough ?
samiam
samiam
Q16 Empty Re: Q16
Post  whatbumper January 15th 2012, 9:26 pm
It doesn't have alky or methane. It does contain MTBE.
And of course the sweat from Chuck Norris's balls. lol!
We run it with great success. Only gas we will use, now if only they would let us switch to alky (what a weight savings on a boosted car).
Q16 Empty Re: Q16
Post  rmcomprandy January 15th 2012, 9:28 pm
samiam wrote:I was wondering about Q16. in my pulls class, Methane or alcohal fuels are not allowed,, will Q16 get me disqualified ?
NO ... the oxygenate in Q16 is MTBE.
The fuel representative at the last Engine Masters Contest was very sure about that.
Q16 Empty Re: Q16
Post  KY JELLY January 15th 2012, 9:30 pm
Tertiary-butyl methyl ether is the oxygenating agent also known as mtbe it is made from a chemical reaction of methanol and isobutylene. Q16 is good stuff , but I don't understand why so many rules are out there outlawing methanol just don't make sense.
KY JELLY
KY JELLY
Q16 Empty Re: Q16
Post  rmcomprandy January 15th 2012, 9:33 pm
KY JELLY wrote:Tertiary-butyl methyl ether is the oxygenating agent also known as mtbe it is made from a chemical reaction of methanol and isobutylene. Q16 is good stuff , but I don't understand why so many rules are out there outlawing methanol just don't make sense.
That compound is NOT an alcohol of any kind.
WATER is not classified as oxygen or hydrogen either.
EDIT: this was merely to inform so as not to "muddy the waters" about this fuel
Q16 Empty Q16
Post  samiam January 15th 2012, 10:27 pm
Now while were at, I read a few post's that said it was best to flush your system out when done running, whats the real scoop ?
samiam
samiam
Q16 Empty Re: Q16
Post  rmcomprandy January 15th 2012, 10:58 pm
samiam wrote:Now while were at, I read a few post's that said it was best to flush your system out when done running, whats the real scoop ?
Draining your system of Q16 after use is for keeping the integrity of the fuel as the oxygenate can evaporate if subjected to atmosphere for extended periods of time.
It has nothing to do with hurting the fuel system.
Q16 Empty Re: Q16
Post  whatbumper January 15th 2012, 11:44 pm
we drain it out just to save the fuel like stated above. of course our motor is 9.5:1 so we just put some pump gas in to drive around at the house.
the only bad parts about the stuff that I know of are it cost a lot and smells & taste (you will know what I mean the first time you pour it) like the worst thing ever. lol!
Q16 Empty Re: Q16
Post  KY JELLY January 16th 2012, 8:27 am
I did not say it was an alcohol , methanol is a chemical it is not an alcohol it is only given that slang term because old timers called it wood alcohol because it is distilled. Methanol is no more an alcohol than mtbe is .
Water is what it is and composed of what it is .
KY JELLY
KY JELLY
Q16 Empty Re: Q16
Post  yellowhorse7 January 16th 2012, 10:22 am
It contains large amounts of magic and mystery.
yellowhorse7
yellowhorse7
Q16 Empty Re: Q16
Post  bbf-falcon January 16th 2012, 10:41 am
Will it corrode your Alum. carb parts or reg. in any way if left there for long periods of time?
Q16 Empty Re: Q16
Post  Barney January 16th 2012, 10:45 am
yellowhorse7 wrote:It contains large amounts of magic and mystery.
Shannanigans
Barney
Barney
Q16 Empty Re: Q16
Post  dfree383 January 16th 2012, 10:48 am
VP and others even make better stuff.... only problem is the $$$$.
Q16 Empty Re: Q16
Post  whatbumper January 16th 2012, 11:13 am
bbf-falcon wrote:Will it corrode your Alum. carb parts or reg. in any way if left there for long periods of time?
been running it for 3 years with zero signs of any damage.
Q16 Empty Re: Q16
Post  rmcomprandy January 16th 2012, 11:13 am
No more than pump gas with oxygenate as part of it.
Q16 Empty Re: Q16
Post  bigblok2000ranger January 16th 2012, 3:08 pm
My engine builder says 35-40hp and mine is not gonna be much higher compression than you have so I am running it, I could see how some classes would not allow it though.
bigblok2000ranger
bigblok2000ranger
Q16 Empty Re: Q16
Post  John Myrick January 16th 2012, 3:55 pm
What is the optimal compression ratio for the use of methanol ?
Q16 Empty Re: Q16
Post  richter69 January 16th 2012, 4:23 pm
I've used it as low as 9.5-1, it seems the lower comp stuff gets a better "kick" from it, but more comp = more power.
Q16 Empty Re: Q16
Post  John Myrick January 16th 2012, 4:56 pm
richter69 wrote:I've used it as low as 9.5-1, it seems the lower comp stuff gets a better "kick" from it, but more comp = more power.
The things that make ya go hmmmmmmmmm
Thanks for the info
Q16 Empty Re: Q16
Post  jasonf January 16th 2012, 5:25 pm
Now that is funny as shit.
At the tech seminar Phillip said 20 hspr is normal.
Q16 Empty Re: Q16
Post  samiam January 16th 2012, 7:20 pm
Thanks for all the imput. when the new season starts I will try it out.................
samiam
samiam
Q16 Empty Re: Q16
