Header angle
Header angle
Is it normal to have the driver's side header collector pointing at a different angle (further downward) than the passenger side? It is not parallel to the ground.
I am unsure of the brand of headers I have. They are 2" primaries w/3.5" slip-on collectors. The driver's side also extends further back than the other one. I am wanting to put some mufflers on and wondering how to line everything up without some major engineering.
thoughts?
thoughts?
460Dave- Posts : 108
Re: Header angle
i had a set of hooker headers like that I replaced them with Kooks
Larry Williams- Posts : 884
Re: Header angle
If the headers you mention haven't been coated, find a common area which all primary tubes can bend a little, heat with a bud, use a timber close to the diameter of the collector and place them where you like.
Dave.
Dave.
LivermoreDave- Posts : 972
» Drive Shaft angle vs Pinion angle
» Need some advice on a pro street truck build
» ackerman angle
» Pinion angle?
» torque angle
» ackerman angle
» Pinion angle?
» torque angle
