torque angle
torque angle
i got new bolts from Lem for my rods cuz i realy didnt know how old or used they are.i just torqued them before to 65#.now i have new bolts with instructions! they say tq to 30# then pull 42* on a tq angle,i bought a new one today and it's easy to use BUT,i used my tq wrench to pull the 42* and about shit when i saw the tq# at 30* so i quit. is it normal for the wsb oliver bolts to be over 75#? i'm not sure how high it'll be @42*,just wanted opinions before i kill a new set of bolts.thanks
Re: torque angle
I do not have a perfect answer but , I would not tq less that 75# with the proper lube.
Re: torque angle
i'll go the 42*'s if it's normal for them to be that high tq.it looks like they'll be 85-90#. hell the main studs were only 90#with the lube that came with them.Lem Evans wrote:I do not have a perfect answer but , I would not tq less that 75# with the proper lube.
Re: torque angle
I do not know if they need to be 85....not less than 75 is what i know.
The mains at 90# is what is gonna screw you
Re: torque angle
you dont think i'm gona listen to the instructions do you?Lem Evans wrote:I do not know if they need to be 85....not less than 75 is what i know.
Re: torque angle
Maybe is was 90 lbs plus 42°
Curt- Posts : 2791
Re: torque angle
thats what i ran last time with the old bolts,lucky i guess.i'll go the 42* and see what it ends up at.just wanted some opinions.thanksLem Evans wrote:65# is too little...in this application.
Re: torque angle
Whatever method you decide on, tighten 1 up w/o a bearing in it and check to see if the I.D. of the rod is round and to size at that tightness. Use the bolt stretch gage if you want to see where you're at for sure, if you can afford to replace those wsb bolts you can afford a gage. lol Good luck
BradB- Posts : 43
Re: torque angle
good point,thanks.BradB wrote:Whatever method you decide on, tighten 1 up w/o a bearing in it and check to see if the I.D. of the rod is round and to size at that tightness. Use the bolt stretch gage if you want to see where you're at for sure, if you can afford to replace those wsb bolts you can afford a gage. lol Good luck
Torque Angle
I've been running Oliver rods for years. I always use torque/angle to get close, but use a micrometer with a vernier scale that can be read to .ooo1" resolution to measure the resulting bolt stretch. At the end of the day, stretch is what you are striving for because it is directly related to how much force (preload) is on the bolt.
You'd be surprised at how inconsistent the amount of torque that's required to achieve the correct results. That, of course, is why you don't use torque to set the bolt preload if you need precise results.
I create a simple chart to record the free length of each bolt, its position in the engine, the target stretch value, and the angle that was necessary to achieve the target. Each year, when I teardown, inspect, and clean my engine, I keep the bolts in the same order and compare the measurements to the previous year's assembly.
If you want to do the job right, follow Oliver's instructions to the letter AND measure the resulting stretch. You'll sleep better.
Chris
Chris
crazmo- Posts : 2
» Drive Shaft angle vs Pinion angle
» ackerman angle
» Spoilers what angle?
» Need some advice on a pro street truck build
» Header angle
» ackerman angle
» Header angle
