I didnt make the rules!
I didnt make the rules! Empty I didnt make the rules!
Post  papamoe January 28th 2012, 6:13 pm
470ci limit,iron heads with stock valve locations, 4150 carb,flat tappet cam,gas only. Small blocks up to 410ci with the same rules and a 200 lb break. I wander how bbf would stack up against bbc witch we all know will compete. I researched the heads a bit but I cant tell witch iron head would be the best and also able to find.I already have a block bored to 4.440 and hard blocked that i chickened out of using on my 557.Could you offset grind a 460 crank to make it work or would you go a different way?The flat tappet cam deal scares me also.Can you make enough power with this combo that a flat tappet would not be durable because of spring pressure or is this not an issue?Its sopposed to be a poor boy 1/8 mile heads up but i guess its like the last class i built for it wont stay that way long..
papamoe
I didnt make the rules! Empty Re: I didnt make the rules!
Post  LivermoreDave January 28th 2012, 7:39 pm
papamoe wrote:470ci limit,iron heads with stock valve locations, 4150 carb,flat tappet cam,gas only. Small blocks up to 410ci with the same rules and a 200 lb break. I wander how bbf would stack up against bbc witch we all know will compete. I researched the heads a bit but I cant tell witch iron head would be the best and also able to find.I already have a block bored to 4.440 and hard blocked that i chickened out of using on my 557.Could you offset grind a 460 crank to make it work or would you go a different way?The flat tappet cam deal scares me also.Can you make enough power with this combo that a flat tappet would not be durable because of spring pressure or is this not an issue?Its sopposed to be a poor boy 1/8 mile heads up but i guess its like the last class i built for it wont stay that way long..
OEM iron heads?
Dave.
LivermoreDave
Post  rmcomprandy January 28th 2012, 8:38 pm
Sounds to me like a spot which would best use the iron CJ heads.
Offset grind a 429 crankshaft to 3.79" or 3.80" stroke and use as much compression ratio as your gasoline will permit.
