Big Hp looking at 1200hp And up, on conv head 460 based block
+21
LanceDavis
HOOK
Oakley Motorsports
jones
'65 T-BOLT
deliveredfast
bb429power
kjebba
brad
Spencer Elton
25 posters
Page 1 of 4
Page 1 of 4 • 1, 2, 3, 4
Im a racer in a local Outlaw 10.5 (Real Street) N/A class.Im a true Blue Ford Man,Have been racing over 25Years.Also Bracket raced most of that time.Have raced nothing buy fords from Mustangs to Altreds all with ford Power.I currently run a 440inch C3 head windsor makes 900 on Kuntz's dyno.but just cant compete against 632bbc in our class making upwards of 1200hp,Im the only small block left in class and im looking to build conv headed 600in or bigger 460based block.Looking at different heads considered Conventional Headed.Has anyone worked with Boss 9 head? i have seen some work with a 598 on pump gas making 950hp just wondering if anyone has wicked them up maybe 640in and 15to1 comp with c25 racing fuel? Any Info Would Be Appreciated,Thanks Spencer.
Last edited by Spencer Elton on February 13th 2010, 1:05 pm; edited 1 time in total
Spencer Elton- Posts : 27
Re: Big Hp looking at 1200hp And up, on conv head 460 based block
Spencer,
Can you post the rules of the class and then we can give you some direction
Nick
Nick
Rules
Sorry,I dont have a copy of the rules right in front of me.But I can give most by memory.Stock suspension,2800lb small block 3200 big block.Small block ci limit to 440 big block 640,No wheelie bars,No power adders,slicks have to meet 10.5 template,315 drag radial is legal,100#weight addded to latter bar cars,Cars have to appear factory with glass and interior,No Clutchless Trans,Mufflers required,Must be conventional heads no big duke or big chief.C3 Were Oked in class.NO Sheet Metal Intakes.Single Card No Oxygenated Fuels.No Alcohol or Q16 Fuels
so what times do you have to have to be competitive ?
Just what exactly to they consider "conventional"? If the A heads were allowed, you could get close with a tunnel ram and single 4 with a lot of C/R and big cam, but I doubt you would see 1200hp. What heads are being used on the bbc that are considered "conventional" and making 1200HP?
schmitty- Posts : 4538
Cool! You're in the right place to find out... I'm sure some of the big guys will help you out here.
That being said, are reproduction Hemi heads (like Kaase's) considered conventional? If so, that could be your best bet because I highly doubt an A-head or above is considered conventional. Hope you're ready to spend some $$$ though
windsor- Posts : 1167
windsor wrote:Cool! You're in the right place to find out... I'm sure some of the big guys will help you out here.
THE "Ahead" is considered conventional in some classes
if you can run a c head you wouldnt have a problem hitting 1200 plus at 640 in my opinion
brad- Posts : 50
Really doubt that the C would be legal. JMObrad wrote:if you can run a c head you wouldnt have a problem hitting 1200 plus at 640 in my opinion
TravisRice- BBF CONTRIBUTOR
Thanks,for the info the BBC in class have ran 5.30's at 132mph Fastest SB 5.45 126mph The Big Blocks have been testing allready on the 315's and there's talk that they be even faster how.Ive called kaase and was told the boss 9 head was conventional head(based on 1200 production by Ford) .Please send me any info that you guys have heard
Then the Boss 9 would be the way to go, unless you can run an A head...
so can you?
so can you?
Have you heard of any port or flow work being done on Boss 9? Need something in 500 on intake.Ive heard of a new BBC head being worked on in Arkadelphia that flows 520 and still concidered conventional head.Joint venture between To head guys and Edelbrock.this also may be on one of the cars in our class 2010 season,Those heads should make some serious power.
I would be wery suprised if there is a conventional CBB head that would go 520 cfm. i call i´t BS
The Kentucky boys make som nice HP numbers with the a 460 heads. Call Lem or Charlie.
kjebba- Posts : 26
You still haven't told us if you can use A460 heads or not.
windsor wrote:You still haven't told us if you can use A460 heads or not.
don't give a crap if he does or not cuz if it takes 520 cfm to make it in the Class well that shoots the TFS A460 head way out of the water... the A heads around here are conservative maybe around 460cfm or so
the Coug- Posts : 3055
Sorry for taking so long to get back.The A 460 Heads were brought up last Real Street Meeting And Were Not Allowed,Also The GV2 Headed Windsor Motor I Have Flows 440 on intake.Thats On Kuntz's Flow Bench.Makes Over 900hp But still not enough weight difference to overcome the BBC.And being the only SB in class its hard to get the big blocks to add weight (Rule Change) Thats why im trying to get as much info on the BBF,I have Raced a 572BBF in my altred
im guessing the guys throwing out the big numbers on there flow and horespower are full of it. if the a heads not allowed then you might get a set of the boss heads in there theyd flow great but not anywhere near the air those guys are telling you. if not you might be able to do alot of work to some of the scj heads or p-51s with some work they might sduprise you on a 600 inch motor with the right cam. brad
brad- Posts : 50
When you guys say A head and C head, what do you mean? D0VE-C, D0VE-A?
bb429power- Posts : 3129
A HEAD= A460 MOTORSPORT FORD HEAD
C HEAD= C460 MOTORSPORT HEAD
BOSS 429- Posts : 2372
the Coug wrote:windsor wrote:You still haven't told us if you can use A460 heads or not.
I got A460 heads from Steve Vance and they flow 490 at .850 lift.
Last edited by deliveredfast on February 15th 2010, 10:23 pm; edited 1 time in total
deliveredfast- Posts : 358
Duh, it was right in front of my face how did I not catch on to that.BOSS 429 wrote:A HEAD= A460 MOTORSPORT FORD HEAD
I would like to know how they can call a head that flows 520 cfm a conventional bbc head?
IDT makes an A head that flows 520 cfm , but it's a far cry from a conventional head.
Nor is a Thor or a Profiler both above 500 CFM.
I guess the bbc head design is so superior to the BBF head it's easy to get those big flow numbers out of them with out getting away from the stock lay out
Typical chevy biased rules bull sh--.
IDT-572 wrote:I would like to know how they can call a head that flows 520 cfm a conventional bbc head?
Blake, It sounds like the rules comittee is made up of all Chevy guy's,bout like the truck pullers sanctions
I would like to see the info on the Chevy heads
bbf-falcon wrote:IDT-572 wrote:I would like to know how they can call a head that flows 520 cfm a conventional bbc head?
Ditto,,,,,,,,,,,,,,
Happy Flow Bench Inc. on the brand X?
'65 T-BOLT- Posts : 1464
» What cylinder head is the best for a stock block?
» coolant leak between head and block at head bolt location.
» 429/460 block and Head Blueprints
» Oil Leak between block and head
» Head gasket on A96 aluminum block
Page 1 of 4
