Big Hp looking at 1200hp And up, on conv head 460 based block
+21
LanceDavis
HOOK
Oakley Motorsports
jones
'65 T-BOLT
deliveredfast
bb429power
kjebba
brad
Spencer Elton
25 posters
Page 2 of 4 Previous  1, 2, 3, 4  Next
Big Hp looking at 1200hp And up, on conv head 460 based block - Page 2 Empty Re: Big Hp looking at 1200hp And up, on conv head 460 based block
Post  IDT-572 February 15th 2010, 11:33 pm
'65 T-BOLT wrote:Happy Flow Bench Inc. on the brand X?
No I doubt it, they probably do flow that............. Just another screwing the ford guys are getting.
The best flowing conventional head we have other than the boss head is a P-51 Kasse.
Is there another conventional head for a Chevy, that could get to that potential?
Something we (I) are not aware of ?
Maybe the mystery engine head they used in Nascar................
Post  windsor February 16th 2010, 7:53 am
Well, looks like your best bet would be the P51's, unless you have the money and time to go with Boss 9's. You could get over a 1000 probably with either of them at 640 cubes, but it would be easier (and more $) with the hemi heads.
Please let us know about those chebby heads, just to cure the curiosity.
Post  jones February 16th 2010, 8:58 am
Yup, I think it would be interesting to hear what conventional chevy head flows thoes numbers.
jones
Post  Oakley Motorsports February 16th 2010, 11:41 am
John Kyle at Apd gets over 500 cfm out of the brodix Head-hunter head With ti valves etc.
Oakley Motorsports
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Oakley Motorsports February 16th 2010, 12:21 pm
Guys, remember it is not always about flow numbers. Where does it make power, What is the average power, How much power on the shift, how tight can I run the convertor, what are the flow numbers at 6 and 700.
Years ago we picked up my a-heads 20 numbers at peak and all I seen was a little mph and a loss in 60, 330.
Coug I understand what you are saying but Lawes and Charlie are consistently in the upper 470 and low 480's with stainless 2.350 stainless valve. My a-heads are in the 490's and a few bust 500 but not without 30 hrs of work after normal port job and combustion chamber work.
All I am trying to say is do not underestimate the A-head and its ability to produce. I beleive we are just beginning to see what the p-51 can make happen. It is going to take several guys that are capable of tuning an engine and can give good feedback to actually know what these heads can produce.
Oakley Motorsports
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  IDT-572 February 16th 2010, 12:30 pm
Oakley Motorsports wrote:John Kyle at Apd gets over 500 cfm out of the brodix Head-hunter head With ti valves etc.
Is this head considered a conventional head ?
Just curious as what parameters it calls for to qualify to be a conventional head?
Post  dfree383 February 16th 2010, 12:35 pm
If it will bolt on a Factory Chevy Block, has Big Valves and Flows more than everybody Else it's Conventional according to the rules the Chevy guys make up !!! Laughing Laughing
Post  IDT-572 February 16th 2010, 12:38 pm
I would seriously like to know............. I hear this all the time. Conventional and 500 cfm just seem not to go together in the same sentence.
I am sure it's different from one sanctioning body to another, but I would like to hear one description.
Post  dfree383 February 16th 2010, 12:45 pm
Blake,
Where you in the room when Darrin Morgan was talking about Texas Pro Stock? Making over 1200 hp with "Conventional" BBC heads? I believe he mentioned doing it with 450ish cfm......
Post  windsor February 16th 2010, 12:58 pm
http://www.460ford.com/forum/showthread.php?t=133325 <--- very good reading for Spencer on the P51 heads on a 562" engine.. I hope KY doesn't mind me posting that.
http://www.brodix.com/heads/headhunter.html <--- those are the heads from the Brodix site. They call them "conventional"...and I have no idea what that means in regards in how they compare to a stock-type head. They sure flow some air!
Post  Oakley Motorsports February 16th 2010, 1:04 pm
The BRODIX Head Hunter series represents the cutting edge of conventional big block technology. These heads are 100% CNC ported and utilize features such as, oval-shaped intake ports that flow an amazing 465 cfm and newly designed exhaust ports that flow 308 cfm with only a 1.850 exhaust valve. Standard features include an extra thick deck, high valve cover rail, and the best castings in the business.
copied from brodix site
understand we are talking about the guy(John Kyle) who was in on the design of these heads finish porting work. Not out of the box from Brodix.
Oakley Motorsports
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  dfree383 February 16th 2010, 1:13 pm
Nice heads, Seem to Flow about Like A460's?
Post  IDT-572 February 16th 2010, 1:28 pm
That head looks to be a stock port entry height also, exhaust looks raised but it might not be, hard to tell.,
Looks like us Ford guys just got our ass's handed to us.....................
We don't have anything close to that in a stock configuration wedge.
Post  Spencer Elton February 16th 2010, 2:57 pm
Hey this is Spencer again.Just to answer a few more questions.First thing head hunters and big dukes are not allowed in class,and Deck height limit to 10.320 same as ford big block. Also i know what your saying about flow #'s i just brought that up to tell you guys what im up against.I know that a 500in pro stock motor doesnt require as much flow in the head if u have it camed/2 carbs/sheet metal intake/and 9500 rpm shift range.But if your going to have a 640inch motor with usable rpm and the right coverter Single carb cast manifold and auto trans(PG or 3speed)most will have to flow around 500cfm intake to make over 1200hp Both my 440 SB's have high shift ranges the C3 Yates headed Flow 390cfm intake at 800lift and shift 8800 to 9100 and you cant let it drop below 7600 or the motor wont recover back into HP range.The GV2 motor(440CFM Head) Has to shift at 9500 and you dont won,t it dropping below 8100 or its out of its window also. Thanks Again Spencer.
Spencer Elton
Spencer Elton
Post  IDT-572 February 16th 2010, 3:12 pm
Spencer Elton wrote:Hey this is Spencer again.Just to answer a few more questions.First thing head hunters and big dukes are not allowed in class,and Deck height limit to 10.320 same as ford big block. Also i know what your saying about flow #'s i just brought that up to tell you guys what im up against.I know that a 500in pro stock motor doesnt require as much flow in the head if u have it camed/2 carbs/sheet metal intake/and 9500 rpm shift range.But if your going to have a 640inch motor with usable rpm and the right coverter Single carb cast manifold and auto trans(PG or 3speed)most will have to flow around 500cfm intake to make over 1200hp Both my 440 SB's have high shift ranges the C3 Yates headed Flow 390cfm intake at 800lift and shift 8800 to 9100 and you cant let it drop below 7600 or the motor wont recover back into HP range.The GV2 motor(440CFM Head) Has to shift at 9500 and you dont won,t it dropping below 8100 or its out of its window also. Thanks Again Spencer.
Find out for us what Chevy heads are legal and let us know.
Post  Spencer Elton February 16th 2010, 3:23 pm
Me again. I made a mistake on last post Head Hunters are alowed.Big Duke Big Chief Are Not Alowed,The head hunters are were there flowing big #s 460cfms,----- My little Mustang weighs around 2870#'s with me in it after scaled and weight added,it has 1.24 60ft leaving at 4000rpms on Tbrake,Killing 15degrees for 1.5 Seconds into the run,You have to do this to keep from flying the front end on these stock suspension cars.(wheele bars Not allowed this car has drug the bumper at the 330's when all the timing comes back in).Then when you do this Its hard to make a SB recover back unto its HP Window.
Spencer Elton
Spencer Elton
Post  Spencer Elton February 16th 2010, 3:32 pm
Also i would like to add the fellow racer Posting under 429boss has give me some real good info on the Hemi head set up looks like thats probley the way to go in trying to make serious BBF power.Until the BBC guys find a way to outlaw that set up.Thanks Spencer
Spencer Elton
Spencer Elton
Post  Spencer Elton February 16th 2010, 4:15 pm
Big Hp looking at 1200hp And up, on conv head 460 based block - Page 2 Img_0010 Thats Almost as big as 460.
Last edited by Spencer Elton on February 17th 2010, 10:48 am; edited 1 time in total
Spencer Elton
Spencer Elton
Post  windsor February 16th 2010, 4:34 pm
Nice ride, Spencer! Rich (Boss429) should be able to help you out really well with the hemi combo. You'll get some of them chebbie boys whining about running a hemi, but OH WELL! cheers The broader torque curves of the BB's will help you with your narrow power windows of the SB.
Keep us updated.
Post  Spencer Elton February 16th 2010, 5:57 pm
Thanks .
Spencer Elton
Spencer Elton
Post  BOSS 429 February 16th 2010, 11:15 pm
hi spencer
lot going on next few days, i have 2 engines i have to have ready by fri,and one to dyno monday, but i will be spending time on a few things for you later tonight,and tomorrow
-rich
Post  Spencer Elton February 17th 2010, 10:12 am
Man I would love to be there to see one of Hemi's on the Dyno .I wonder how long it would take to drive up there.
Spencer Elton
Spencer Elton
Post  BOSS 429 February 20th 2010, 12:35 am
just sent you other info before this one, give me a call tomorrow, having problems with my pms
-rich
Post  BOSS 429 February 20th 2010, 12:36 am
Spencer Elton wrote:Man I would love to be there to see one of Hemi's on the Dyno .I wonder how long it would take to drive up there.
this one is a ex514 iron head, 1 carb, the hemi is ready but have to do this one first
Post  Spencer Elton February 20th 2010, 7:56 pm
Got The Info Probley get back with you Monday Thanks Spencer
Last edited by Spencer Elton on February 20th 2010, 7:57 pm; edited 1 time in total (Reason for editing : Spelling)
Spencer Elton
Spencer Elton
