Head gasket on A96 aluminum block
Last edited by JBR-3 on October 17th 2020, 3:50 pm; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
Re: Head gasket on A96 aluminum block
Last edited by JBR-3 on October 17th 2020, 3:51 pm; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
JBR-3 wrote:Not one person on here has run into something similar to this ?
Don't use oring with 1028.
How many is "a few' above the deck?
Has the block been run before?
In that situation where I would like to use a 1028 gasket, I put copper wire into the o-ring grooves and machine them flat to the deck.
JBR-3- Posts : 266
JBR-3 wrote:Thanks much gents.
The liners are above deck .0018 ~ .0020, best that I can measure, all of them.
Yes. block is used, I don't know the build/output. I can't measure the current deck height,
so I don't know if it has been decked, but they are the original liners.
I always thought liners had to be above deck, but maybe this is incorrect. The block does grow
and lash increases. But the liners are seated on their register basically right at the top, so if the
block grows say .012", I would think it would actually push the liner up in the bore along with the
block aluminum.
I've used the 1028 with the sleeves ~ +.002". I feared that the block being new the sleeves might settle. Worked okay.
When the engine was freshened I had the sleeves milled flush with the deck.
Last edited by JBR-3 on October 17th 2020, 3:52 pm; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
I've used copper wire before, hammered it into place, and then gently filed away the excess, with no issues. Try different diameters of wire to find the one that leaves the least amount to file off.
pmrphil- Posts : 170
JBR-3 wrote:Randy, what do you think about using Devcon to fill the O-ring groove ?
I have never tried using copper wire, like .035 diameter, maybe 20-ga copper.
Do you try to squish/hammer it into the groove with a brass hammer ?
I use wire which is only a couple thou bigger diameter than the groove is wide and force it into the groove just like the original steel O-ring but, simply made of copper. I imagine that any SOFT metal wire of the right diameter would work fine.
» What do you use for cleaning the block and head gasket surfaces ?
» M-6051-B460 head gasket on stock block?
» Head Gasket ?
» If you swap from iron block to aluminum block,,,
» coolant leak between head and block at head bolt location.
» Head Gasket ?
