M-6051-B460 head gasket on stock block?
M-6051-B460 head gasket on stock block? Empty M-6051-B460 head gasket on stock block?
Post  the tree man March 21st 2020, 1:33 am
Previous owner of my SCJ heads expanded the chamber a bit at the exhaust valve to match the 4.565 bore of the previous motor. I knew they had extra CC's when I checked it but didn't realize from where until I laid my 1018 gasket on it this eve and it's hanging over the edge. Is the B460 gasket OK on a stock block? Can't find the application. Thanks.
the tree man
the tree man
M-6051-B460 head gasket on stock block? Empty Re: M-6051-B460 head gasket on stock block?
Post  bosshoss March 23rd 2020, 2:16 am
i believe the B460 gasket is the same as the fel pro 1028. but sold in sets of two for half the price of the fel pro. good for 4.600 bore on a ten bolt block.
Lem Evans used to keep them in stock..
dkp
bosshoss
bosshoss
Post  Lem Evans March 23rd 2020, 7:14 am
bosshoss wrote:i believe the B460 gasket is the same as the fel pro 1028. but sold in sets of two for half the price of the fel pro. good for 4.600 bore on a ten bolt block.
dkp
Ford racing no longer services that part number.
Post  the tree man March 23rd 2020, 10:55 am
Hopefully my luck has turned around then. Found a set on amazon Canada and it was the last one so I pulled the trigger hoping they'd fit. Old stock I guess. When I found them it was the night before the border closed they were $94 CAN,the next morning after it shut down and I placed the order they shot up to $107. Still a smokln' deal for up here. Should solve my near catastrophe with the 1018's.
the tree man
the tree man
