If you swap from iron block to aluminum block,,,
If you swap from iron block to aluminum block,,, Empty If you swap from iron block to aluminum block,,,
Post  jones November 18th 2015, 10:30 pm
I was just thinking down the road a ways. Say my engine combo works great but I wanted to lose weight off the nose of the truck. Is it just as easy as purchasing a aluminum block and having it machined? Can you get an aluminum block with sleeves in the .020-.030 over range?
(If I was going to do it down the road I would be adding a supercharger at the same time.)
jones
